Multitude of probs/conundrums! (1 Viewer)
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
Bailey Approach 740 SE
1. MH been in its covered storage for 7 weeks
2. Centrally locked but alarm not engaged
3. Tracker fitted
4. 180 solar panel fitted
5. Tracker SMS received that battery was low at 9.8 V
6. Went today to pick up van for the weekend, starter battery dead as a dodo
7. I have the mother of all Jackson starter packs so started the beast no problem.
8. Binnacle showed the vehicle with a lock through it warning light . ( vehicle trying to start with a non programmed key , vehicle will not start ) VEHICLE STARTED !
9. Drove home 20 miles with warning light illuminated AND reversing camera not working though live feed to it showing
10. Got home and very bravely turned engine off and 240v hooked up .
11. Turned engine back on ( not a stutter ) , warning light turned off and reversing camera now working
Thoughts? Cheers in advance !
D
Deleted member 29692
The ECU having a benny because of the excessively low voltage?
If all is working OK now then there is no fault to find so don't worry too much, just keep an eye on it.
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Looks like your only problem now is a battery that may have been over discharged and damaged as a result 9.8v is very low
Reactions: DBK
Adbt
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
I'll get it health checked on Monday post weekend away , any idea why it will of discharged to such a low level ?
DBK
18,017
48,064
Plympton, Devon
PVC, Murvi Morocco
I can only suggest see how things go. The fault warnings rather than the possibly non-existent faults may not reappear now everything is charged up.
Apr 27, 2008
11,842
14,071
Hymer low profile
Since 1972
Storage (covered) will discharge the batteries over time. There is always a parasitic drain, just depends how large, you are running at the very least Tracker and central locking, probably quite a few other things you don't know about. At least our uncovered storage allows the batteries to keep fully charged on solar.
7 weeks = 1,176 hours say 60Ah to flatten a 100Ah battery to the point of damage, this only needs a parasitic drain of 20th of an amp (50mA) to do the damage. Only thing to do with covered storage is to charge the batteries occasionally either with EHU or a long run.
funflair
19,331
30,170
Guisborough
MORELO palace
since 2012
About the only time our EFOY. kicks in is when the van is in covered storage, two weeks would be as long as the starter battery would last, don't know what but something or various things are drawing on it.
Martin
