multimeter useage help
Discussion in 'Tech/Mech General' started by Welsh girl, Jul 6, 2014.
  1. Welsh girl
    Welsh girl Funster Life Member
    Nov 7, 2009
    2,672
    1,289
    living the dream.
    Ok. I bought one of these to test our leisure battery. Can you explain how to use it please? The instruction leaflet is double Dutch to me.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,693
    17,303
    YO11 2BD
    If you simply want to check the battery voltage then set the meter to DC volts, probably 20vdc on the scale/dial.
    Put the red wire to the battery positive (+)
    Put the black wire to the battery negative (-)
    The reading on the screen is your actual battery voltage.
    12.6v/12.7v volts is fully charged.....12.0v is fully discharged.
    If you get the red and black wires the wrong way round dont worry....the screen will show a - symbol before or after the numbers.
    Its still the same reading only negative.
    • Like Like x 2
  3. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,182
    14,954
    Leeds the one up North
    The yellow scale on the left is DC volts and the most appropriate on your meter is 50
    • Like Like x 1
  4. pappajohn
    Aug 26, 2007
    29,693
    17,303
    YO11 2BD
    Thanks for the correction....re: volt scale.
    For some reason i never saw the attachment thumbnail and expected a cheap multimeter, not a moving coil..
    • Like Like x 2
  5. pappajohn
    Aug 26, 2007
    29,693
    17,303
    YO11 2BD
    Before taking any measurements, zero the scale using the white screw below the needle.
    Turn it very slowly until the needle lines up on the zero's on the scale.
    A little off and the results could be incorrect.
  6. Mike B
    Mike B Funster
    Jan 16, 2014
    794
    2,290
    Harleston, Norfolk
    For an accurate reading you need to view the needle such that it is covering it's own reflection in the mirror at the bottom. (PARALLAX ERROR)
    • Like Like x 1
  7. pappajohn
    Aug 26, 2007
    29,693
    17,303
    YO11 2BD
    With that type meter ignore my comment about connecting the wires the wrong way.....they MUST go red to positive, black to negative or the needle will try to swing the wrong way.
    • Like Like x 1
  8. scotjimland
    Jul 25, 2007
    28,936
    25,589
    sorry to say, but with an analogue meter of that quality and on a 0-50 vdc scale, it won't be very accurate, it will also be difficult to read accurately.
    If you want to learn how to use a meter, and not just for battery voltage, then my advice is to buy a reasonably priced digital multimeter from the likes of Maplins .. from as little as £20
    easy to use and easy to read..
    [​IMG]
    http://www.maplin.co.uk/p/digital-multimeter-with-voltage-detector-n61lk
    • Like Like x 3
  9. hilldweller
    Dec 5, 2008
    26,859
    25,730
    Macclesfield
    Spot on, you could not tell the difference between flat and fully charged on that. Quite useless.
    • Like Like x 1
  10. The Wino
    The Wino Funster
    Mar 23, 2012
    1,160
    2,074
    leicester
    • Like Like x 1
  11. MicknPat
    MicknPat Funster
    Dec 16, 2007
    628
    2,921
    Touring UK
    • Like Like x 1
  12. scotjimland
    Jul 25, 2007
    28,936
    25,589
    Like most things in life you get what you pay for David. It doesn't say on the info what the % accuracy is.. so presumably it's not great..
    If it's only for using once in a while to test the battery, then it will do the job... it's better than a cheap analogue
    If you are going to use a lot I would buy something a bit better .. look for % accuracy..
    an example is the Maplins one in my link that gives DCV accuracy as +/- 0.5%
    You can of course go to the other extreme and buy a pro meter like a Fluke, but they are over £100
    • Like Like x 1
  13. Welsh girl
    Nov 7, 2009
    2,672
    1,289
    living the dream.
    it is only for occasional use. These are the instructions.
    We cant make head nor tail of them
  14. The Wino
    The Wino Funster
    Mar 23, 2012
    1,160
    2,074
    leicester
    Quite right but from the original post I thought within 5% would be fine!! I'm a bit of a rough and ready DIY bloke and it would be well worth the extra if your'e using it a lot but for a quick check on the battery volts would probably be more than up to it and there is a tenner towards the battery if you need it :). Our local (not part of a big chain) car spares place would check it for you foe free (and they are honest) just don't try one of the chains where the staff are on a target:(
    David
    • Like Like x 1
  15. Geordies
    Geordies Funster
    May 29, 2013
    944
    2,138
    Tyneside
    Just a point about the multi meters above and others of the same types. Even if it has a 240v range it is NOT advisable to use these meters to check mains voltages, it is a safety issue. You really want a martindale tester for mains work, much safer.
  16. stevec
    stevec Funster
    Sep 24, 2013
    612
    206
    Norwich
    Some multimeters have three sockets (as the screwfix one). The left hand one is for measuring amps (current). The right hand one for volts (centre is negative -common). Make sure you use the correct one!
  17. rickwiggans
    rickwiggans Funster
    Apr 2, 2014
    75
    56
    Lancashire
    Evidence please.
  18. Techno
    Jul 28, 2010
    14,182
    14,954
    The probes are inappropriate for mains work. They should incorporate fuses and the contact tip should be shielded all the way to the tip.
    • Like Like x 2
  19. Techno
    Jul 28, 2010
    14,182
    14,954
  20. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,748
    3,252
    Eastbourne East Sussex
    This is the problem when they use google translate on the original Chinese. Do not read these instructions, you will go mad :mad::mad:
    • Like Like x 1
