Multimeter Advice
Discussion in 'Motorhome Chat' started by golly, May 12, 2015.
  1. golly
    golly Funster
    Aug 16, 2009
    1,238
    2,179
    Co Durham
  2. Geordies
    Geordies Funster
    May 29, 2013
    996
    2,294
    Tyneside
    Yes, fine for working on vehicles, don't use it anywhere near 240v.
    • Like it Like it x 2
  3. Old Soldier
    Old Soldier
    Apr 10, 2010
    902
    1,484
    Wells in Somerset
    Spec indicates it can measure AC voltage too....
    • Like it Like it x 1
  4. Geordies
    Geordies Funster
    May 29, 2013
    996
    2,294
    Tyneside
    Yes, it can measure up to mains voltage, but it's insulation qualities and length of exposed metal tip makes it unsafe to do so.
    • Like it Like it x 6
  5. Serendipitous
    Serendipitous Funster
    Aug 4, 2012
    357
    314
    Devizes
  6. Glandwr
    Glandwr Funster
    Jul 10, 2014
    695
    2,005
    the Berwyn Mountains
    Two pieces of advice, don't buy the cheapest (I've thrown away 3 over the last 5 years) and buy one that has an auto off, or if you are anything like me you will find a flat battery when you most need it.
    Dick
    • Like it Like it x 3
  7. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    4,012
    9,217
    NW England
    I still can't work out how I made it to 50 before discovering the multimeter - extremely handy piece of kit. Only problem is I find the copper cored probe leads are brittle and snap after a fairly short time, so get some spares in. Also, a weak battery will give false readings.
  8. etap
    etap
    Nov 19, 2014
    256
    233
    Somerset
    This is not advice but like you my knowledge of electricity sounds a bit like yours, I have always bought a cheap 4.99p tester and find it useful for checking all sorts of batteries and also for checking wiring to see if it is live, however, I do not use it for 240v electrics as my knowledge is not sufficient.
    Etap
  9. Serendipitous
    Aug 4, 2012
    357
    314
    Devizes
    Perhaps the best advice is if you don't know what your doing get someone who does!
    • Like it Like it x 4
  10. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,958
    23,796
    Narrfoook
    Have a look at what Halfrauds have to offer..
    I have maybe 7 or 8 meters spread around.. from the cheapest to the most illustrious !
    Unless you are looking for .05v accuracy almost anything will do.. But as mentioned, the cheaper ones do go out of whack after a couple of years.
    Of course even inaccurate meters are still just fine for tracing 95% of problems..
    I would tend to go for something middle of the road .. about £20 worth or so
    As to using them on AC.. Well that is a personal thing.. I aint exactly short of experience and actually prefer long probes.. Absolutely nowt worse than finding a probe will not get in to a recessed check point !!
    I would suggest stripping a bit of sheathing from some thin wire and sliding it on the probes covering all bar maybe 5mm .. Doing that means the probes are safe to use but if need be, the sheathing can be slipped off and a long probe is once again available :)
    One make I would ( sadly ) avoid nowadays is Fluke.
    They were one of the best out there for donkeys years.. Something changed about 3 years ago though.
    In the past year I have come across several ( and some have been in the upper price range ) that have gone seriously off the beam
    Yet I have one ( somewhere ! ) that I bought in the early 90's and along with some other stuff had checked.. It was still absolutely spot on !
    But to reiterate .. Unless you are intending to break in to electronics, almost any meter will be fine for fault finding on your motor home and that Sealey you posted a link to will be just fine (y)
    • Like it Like it x 5
  11. stevec
    stevec Funster
    Sep 24, 2013
    646
    215
    Norwich
    Well, Jaws, if recent ones have gone downhill a bit, how about an Avo 8. Don't you just love those old analogue meters.
  12. Gizmouk
    Gizmouk Funster
    Nov 6, 2013
    1,030
    1,826
    Essex
    They're great ... till you forget to check they aren't on current range, and go measure voltage. The noise of the needle hitting the end stop closely followed by a clip round the back of the head from the Apprentice Master still resonates through my head ;)
  13. Jaws
    Sep 26, 2008
    18,958
    23,796
    Narrfoook
    LOL !!! Oh yes.... I started with an AVO 7 and graduated to the 8.. Had it for many years and used to check the calibration with a wobulator
    It was always BANG on .. Eventually it got nicked from the Telefusion van, but by then digi ones were available so replaced it with a digi..
  14. Serendipitous
    Aug 4, 2012
    357
    314
    Devizes
    Unfortunately the old analogue meters had some deadly results, am aware of at least 1 chap killed by the fireball resulting from checking for the presences of 415vac using an avo minor set on ohms. Without fused leads I'll hasten to add. Not many fitted in those days.
  15. Daifuse
    Daifuse
    Feb 20, 2013
    184
    310
    Milford Haven
    Still got an AVO 8 and a Panclimatic version too. But for most work these days I stick to my 20 year old Fluke. The only drawback to the OP's choice is it only measures up to 200ma., perhaps not enough for some checks such as charging current or current drain.
  16. Rob e Lee
    Rob e Lee Funster
    Apr 16, 2012
    444
    558
    Surrey
    Totally agree - a real pain when checking socket outlets! When inspected by NICEIC these leads are a requirement but after inspection -----------
    Rob
  17. scotjimland
    Jul 25, 2007
    29,041
    25,733
    Suffolk
    I would suggest for the non electrical competent DIYer and or motorhomer.. and expert alike, for testing if mains supply is present, a much safer and dare I say easier to use is a no-contact mains tester..
    such as http://www.screwfix.com/p/c-k-non-contact-voltage-detector/9396d
    I am competent and qualified, but still find this an extremely useful bit of kit to prove if a socket, EHU post socket, or EHU cable is live.
    Caution.. it does not prove that an appliance, cable or accessory is 'dead'.. it only proves that it is 'live' ..
    this applies to all mains testers..
  18. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,368
    18,055
    YO11 2BD
    Only serious problem i found with those Jim, i had 3 x 2.5mm t+e exiting a live consumer unit and parallel to each other In the same entry point.
    One was connected to a breaker and two werent.
    all three showed live as they exited the board using the volt pen.
    So....do not rely on for fault finding if wires run close together
  19. Sidney
    Sidney Funster
    Jan 27, 2013
    1,301
    851
    Stamford
    Back to the OP
    I'd say that multimeter is fine. YouTube is a good way to learn how they work...
  20. scotjimland
    Jul 25, 2007
    29,041
    25,733
    Suffolk
    as I said John.. only for proving if something is live.. not fault finding per see
