injebreck99
Exactly the same layout as ours, excellent equipment so far.
What controller is that Techno?My controller on a good day producing over 6 amps more than the combined panels rated output (that is in MPPT mode) you can recognise this by the charge voltage which will only be a little over half a volt higher than the battery voltage. Bringing the voltage down allows higher current for the same wattage. A PWM regulator cannot do that
This will cost about £110 by the time parcel farce hit you from Taiwan
This one, the same as mineWhat controller is that Techno?
Mine is the 300 watt modelThis one, the same as mine
Broken Link Removed
Had it over 3 years now and no problems.
Haha, of course it is, that looks a very nice job you've done, very professional. I much prefer the symmetrical layout as you've done than random panels in whatever space allows.Mine is the 300 watt model
Yes it will work fine but not as an mppt. It will be a fake with PWM regulator guts.When is a MPPT controller not an MPPT controller? I splashed out on the least expensive MPPT I could find - £13.95 including delivery for a 20 amp. It works, except the stick on fascia is all crinkled from the med sun and heat, and thus you can't see the led lights properly. I am prepared to think that I could have spent more, but there is such a wide price range, with some costing over £100, some less that £20. How can you tell which one is good value? Or even if it IS an MPPT. Where is the price break? As I say, it seems to work fine, but I have never checked the performance.
I have no personal experience of the Victron, I can only recommend what I use and I've yet to hear a negative report on that.Andy.. @Techno100 ....in your opinion Is it better to buy the
victron MPPT controller. I am using the tracer 10a as posted earlier in this thread coupled to a 150 watt panel. It works well enough but wondering would the victron squeeze out a few more mA.
I am going to add another 150 panel in any case.
http://www.motorhomefun.co.uk/forum/threads/mppt-controllers.111926/page-2#post-1478141and this one would be? i have a victron 100/30 but you cant take it apart not that i would want to, bit pricey but does the job.
Steve
