Mph to kph (1 Viewer)
kelv
672
895
leicester
Carthago 145
When driving abroad in my motorhome I have trouble seeing the tiny red kph on my speedo fiat based cab do other funsters have the same problem or is there some sort of sticker you can buy to put over the top of the mph? Or maybe I should buy some 2 inch thick glasses
gozomike
Funster Life Member
1,001
863
Warwickshire - sometimes - but not often
Wildax Constellation
Since August 2008
I just set my GPS to show the speed in Kph, much more accurate than the actual speedo. It also shows the max speed for most roads but that is not always correct.
funflair
19,342
30,216
Guisborough
MORELO palace
since 2012
We have MPH overlay on the KPH speedo but I just look at the say nav and that gives me the speed limit as well.
kelv
kelv
672
895
leicester
Carthago 145
Techno 100 The one in the pic the mph are still larger than kph
funflair
19,342
30,216
Guisborough
MORELO palace
since 2012
OK just realised the OP wants to read the speedo in KPH, buy a LHD would be one suggestion or as suggested above set your sat nav to KPH.
kelv
kelv
672
895
leicester
Carthago 145
Sounds like fitting a dial would be a large job just thought it might be possible to stick one over the glass and remove on return
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Techno
Jul 28, 2010
15,475
20,756
May 2010
5 to 10 minutes to swap once you've done it for the first time.
kelv
kelv
672
895
leicester
Carthago 145
Wow 5 mins sounds ok I will look into sourcing one or I may have have to change plates like Dave says if I keep having late night parties with funsters
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
1kph = 5/8ths of a mile
so!
30 mph=50kph
50mph= 80kph
4.55 litres = 1 gallon
Ergo 22litres = 5gallons
Seemples innet?
Techno
Jul 28, 2010
15,475
20,756
May 2010
Mine is for sale. It is from a 2008 3 litre Ducato. I changed mine to the dual dial as I posted.
Jaws
23,836
72,461
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
A quick rough and ready that I use ( helps pass the time too ! )
divide by 6 and times by ten.. Not dead on but close enough
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes I'm always learning but I'm at the age where I've forgotten more than I'm retaining :giggle:
mikebeaches
5,393
8,597
Bristol
Rapido V68 Van Conversion
Since 2009
We keep a simple cardboard hand-written crib sheet handy in the cab that I knocked up during one trip:
30kph = 18.75mph
40kph = 25mph
50kph = 31.25mph
60kph = 37.5mph
70kph = 43.75mph
80kph = 50mph
90kph = 56.25mph
100kph = 62.5mph
Just glance at it occasionally, if a new speed limit pops up in order to be absolutely certain we're not going too fast. Use the sat-nav too for an accurate speed check, but hadn't thought about changing it from mph to kph - good idea. :)
Mike
DBK
18,022
48,089
Plympton, Devon
PVC, Murvi Morocco
Changing the GPS to metric units, as suggested earlier, is the simplest answer. It's not just speed but also distance it will then display in the local units.
C
Chockswahay
Just take the first 'number'from the KPH speed and multiply by 5 and put a 0 on the end then round up ....
Sounds tricky........... but really quite easy
E.G. 50kph = 5 x 6 = 30mph 80kph = 8 x 6 =50 mph 100 kph = 10 x 6 = 60 mph
It does work I promise you:eek:
lorger
9,661
90,507
Dumfries
Knaus Sun 650MEG
Get some coloured tape and stick it next to the speed limits IE 30mph and 70mph or what ever it is in the country you visit
Techno
Jul 28, 2010
15,475
20,756
May 2010
I disagree
There is too much to think about without mental arithmetic.
Sat nav is good and accurate. My dual display suits me fine personally but there is nothing better than a clear unambiguous dial.
C
Chockswahay
True, it does require a good grasp of the 6 x table:)
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Another way is to add on half of the mph figure then the 1st number of the original number Its not exact but near enough
Ex:
50mph = 50+25 +5 = 80.
70mph = 70 +35 +7=112
