MPG....speed related savings
Discussion in 'Motorhome Chat' started by Chockswahay, Aug 21, 2014.
  1. Chockswahay
    Chockswahay Read Only Funster
    May 29, 2012
    3,097
    4,801
    After nearly 20000 miles in our Fiat 130hp van I have observed the following:
    50 mph gives 43 mpg
    60 mph gives 35 mpg
    70 mph gives 28 mpg
    Generally depending on how quiet/busy the roads are, I tend to cruise between 50 and 60. All these speeds are 'indicated' and in reality are about 4mph fast according to the GPS
    My average overall is 38mpg
    The 'shocker' is that going just that little bit faster uses a massive amount of extra fuel for little saving in time and a lot more stress.
    I am referring to constant speeds set with cruise control where possible. It does of course depend on the type of journey and time available.
    For me...... cruise control on......music on....,. Sit back and relax :):)
    The journey takes a little longer and I spend less on diesel. It works out to be a 'free' bottle of wine every 100 miles :D
    • Like it Like it x 13
  2. Puddleduck
    Puddleduck Funster
    Jan 15, 2014
    6,710
    14,441
    Scottish Borders
    Chose your time of travel to avoid rush hour and then enjoy the journey.
    The journey is part of the experience so why rush it?
    • Like it Like it x 10
  3. Puddleduck
    Puddleduck Funster
    Jan 15, 2014
    6,710
    14,441
    Scottish Borders
    And be a courteous driver - pull in and let people pass if they have been stuck behind you for a while. Why create aggro?
    • Like it Like it x 12
  4. MikeD
    MikeD Funster
    Dec 21, 2011
    2,155
    1,883
    London
    Totally agree, we just enjoy the journey and hardly ever go over 60mph. (y)
  5. Bertie Bassett
    Bertie Bassett Read Only Funster
    Jul 25, 2014
    2,743
    8,716
    Mine is the Boxer with a 130 engine, I normally get approaching 37 on long steady runs mostly using cruise. Only time I've bettered that was after taking advice from a mech to run 3 tanks of BP Ultimate through it. 5p a litre more than straight BP and about 8p more than supermarkets. Got up to 39 to 40 which didn't in my view justify the extra expense. What I noticed on changing back was a loss of a smoke free, smooth run in all gears. I also thought the engine was a bit noisier but as I'm deaf as a doorpost that was probably aural make believe. I agree that a steady 50-60 does give much better mpg and so I keep to that even on motorways.
  6. injebreck99
    injebreck99 Funster
    Dec 5, 2011
    1,207
    1,315
    norfolk
    Are these figures from the computer readout, or actual figures from old fashioned neck to neck trials?
  7. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,616
    5,689
    Yr Wyddgrug
    "The journey takes a little longer and I spend less on diesel. It works out to be a 'free' bottle of wine every 100 miles"
    (y)
    • Like it Like it x 3
  8. Chockswahay
    May 29, 2012
    3,097
    4,801
    Actual (although I have rounded down for the sake of brevity).
    To my embarrassment I can count EVERY gallon that the van has ever used :eek:
  9. gillnphil
    gillnphil Funster
    Apr 12, 2010
    954
    4,405
    West Suffolk
    I generally set the cruise to 58 ish True speed 55mph. I did a sort of experiment last run out and took notice of the cars that whizzed past. When we turned onto the M25 off the M11 I recognised many of the fast cars. Then again when reaching the Dartford bridge the same cars were just in front again. This is caused by lorries overtaking at snails pace so everyone catches up.
    Moral is theres no point in going faster than the lorries, so stick to 55 and save "loadsamoney"
    Phil
    • Like it Like it x 5
  10. DiggerJon
    DiggerJon Funster
    Jan 25, 2013
    591
    5,547
    Dorchester, Dorset
    I was taught years ago that you have to double your speed to halve the time taken to travel the same distance - and the incremental savings over 50 mpg are hardly worth rushing for!
  11. chaser
    chaser Funster
    Feb 16, 2013
    7,708
    8,772
    uttoxeter
    Never done any keeping at one speed or anything else but check at every fill up and find, it makes no difference to mpg whether we do eighty down the motorway or toddle about at 40 its still between 25 and 28 never been out of that range, it does 100 miles to a quarter tank almost without fail and I fill as near as possible to 380 miles, never varies, iv been with my son and with a mate in their vans and they come up with various mpg according to their computer way above 30 to the gallon but they always end up putting as much or more diesel in when we fill up for the same distance
  12. Bertie Bassett
    Jul 25, 2014
    2,743
    8,716
    No embarrassment there chocks, or should I say join the club? Nothing wrong with being 'cost aware/tight', I'm welsh and it's the only thing I've ever been an expert in.
    • Like it Like it x 2
  13. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,124
    8,357
    Forest of Dean
    Exactly the same here get 23mpg to 25mpg whether driving at 55mph or 65mph or 4250kgs 0r 5000kgs
    makes virtually no difference. The only increase in mpg 2 or 3 is since I had the remap taken off that put it back up to 25mpg which it did before the remap.
  14. andy63
    andy63 Funster
    Jan 19, 2014
    2,225
    8,524
    south shields
    same sort of findings as op. if speed is kept to not much over 50 the range per tank full of fuel goes up dramatically . ie 550miles. if driven at 60+ then it drops to 450 or so.. that's distance driving.
    ta andy
  15. Al-Di
    Al-Di Funster
    Mar 15, 2014
    1,015
    4,069
    prestwich
    our old merc was lucky to do 40 let alone 60 but returned 25mpg constant:)(y)
  16. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,180
    3,014
    Kendal, Cumbria
    My difficulty is going fast enough to keep driving interesting & me awake. I don't find driving stressful at any sensible speed but I do find it difficult to go slow & stay alert. My Fiat 2.8 speedo dramatically over-reads (72 = 65). I use cruise control to run at a real 65 & around 22 - 24 mpg. I don't think I could go much slower. I too log every gallon (litre) I buy & do the calculation every couple of tank-fills or so.
  17. OddSocks
    OddSocks Read Only Funster
    Apr 10, 2014
    479
    395
    Cornwall
    I have been keeping an eye on my consumption too. (1990 Merc 208 D with Aftermarket turbo)
    Guess what I discovered? Once I hit 60 mph (I rarely used to ever go that fast) something just 'lines up' and the thing flies! Up (very slight) hills and down dale! And you know what else? The tank full where I discovered this delivered the best MPG I have ever got from the van! Normal slow driving (55mph max) I get 21.5 on average. Driving at 60 I find I have to start backing off to avoid going even faster - 22.3 MPG!! Best ever - until........ I put 4 new Continental Vanco 2 tires on it last week. Next tank went up to 23.22! Blimey!
    Will keep tabs on this once I have fixed my current problems.
  18. AuldCodger
    AuldCodger Read Only Funster
    Nov 25, 2009
    284
    126
    Motorway just enough to keep out of the LGV guys who are working for a living, never use cruise as I would rather allow the the speed to drop off gradually on a steep incline as opposed to cruise giving it welly.
    Back road speed depends on the scenery and other road users.
    End result 33.2mpg average taken using onboard system and the old belt and braces full tank to full tank method.
    Almost missed the essentials - Fiat Ducato Maxi 130
  19. john kyte
    john kyte Read Only Funster
    Dec 17, 2013
    60
    42
    Salisbury
    Hello your speedo is then reading 9% fast----so your mileometer will also be 9% fast
    So you need to consider this when working out your MPG
    My speedo in an 89 Ford transit is 25% fast----confusing and probably illegal
    This is the result of fitting a gearbox from a van with higher speed differential
  20. PP Bear
    PP Bear Funster Life Member
    Apr 5, 2013
    2,270
    6,878
    UK
    I'm a big believer in this. I'm still on my 7 week trip around the South and always pull in when required :)
    Did it the other day for a delivery van, who promptly tooted and waved his appreciation :)
    Gives us all a better name in the motoring world, which can't be a bad thing :)
    • Like it Like it x 6
