Mould
Discussion in 'Tech/Mech General' started by electricscott, Oct 8, 2013.
  1. electricscott
    electricscott Funster
    Nov 23, 2010
    198
    72
    Buckden Marina
    Here are 2 solutions to mould under the mattress:
    1 cut slots in the bed base (like a 6 pack) and let the air from the garage circulate under the mattress,
    2 put an insulating layer with wooden slats on the bed base to support the mattress
    Which solution would you choose and why
  2. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,284
    13,022
    somewhere
    wooden slats as the air tep would be the same as the hab unit and i would have sum of my blown air ducted under the bead to keep it dry and air moving round
    would not use cutting slots as air in garage will be cold and will create cold spot and more damp or heat the garage and your mould will go away lift matres when not in use
    • Like it Like it x 1
  3. ourcampersbeentrashed
    ourcampersbeentrashed Funster
    Apr 19, 2008
    7,652
    4,284
    East London
    we have never had mould under any mattresses or bench seat cushions.
    So, is the mould problem in newer motorhomes, what do we do to prevent, do we need to do anything?
  4. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,807
    1,027
    Cark, Cumbria
    There is a third option. Put a layer of course/open pore foam(the courser the better) at least 1" thick under the matress.,
  5. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,934
    40,098
    "Slats"... to keep the air temp the same as the room... :thumb:
  6. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,286
    7,991
    West Norfolk
    Ours has slats from the factory and the garage is heated.
    No mould.
    I reckon that's your solution!:thumb:
  7. Allanm
    Allanm Funster
    Jun 30, 2013
    3,186
    4,344
    Cotes d'armor, France
    Our mattress is on slats too and the heater unit is under the bed so it's always warm and well ventilated
    Just make sure you have some sort of airflow under the mattress, still damp air or no airflow around a damp mattress ( even just from sleeping) will cause mould to form eventually
    Allan
  8. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    Our BessieE480 has slats under the Mattress , which is also over the Garage no problems. Pete
    Ps our last Coachbuilt BessieE465, also had slats under the Mattress no problems with that one either
  9. BwB
    BwB Funster Life Member
    Apr 3, 2011
    608
    563
    Brandon Suffolk UK
    The cheap and cheerful option is a sheet of corrugated cardboard - the sort of stuff they make boxes out of. If you can find some about quarter/half inch thick (ask at one of the electrical stores for some of the packing which comes around fridges etc.) this is best. I know it might sound a rubbish solution :) but this was the standard way of preventing moisture build up when I started motorhoming in the 80's. Our first van had the same cardboard under the overcab bed for about 5 years until the motorhome was sold and never had any more problems with mildew under the bed. The next moho had slats which did the same job.
  10. electricscott
    Nov 23, 2010
    198
    72
    Buckden Marina
    Thank you all for your great replies and although I favoured cutting slots (reduces weight) I am unhappy about the temp gradient but boy I did not expect such good alternatives sponge or cardboard is the way to go!
    :thumb:
  11. Gooney
    Gooney Funster
    Jun 2, 2010
    4,772
    7,866
    Flintshire
    Obviously prevention is better than cure BUT if you are unfortunate enough to have black mould staining the best product I have ever come across to remove it is HG mould spray, in all good hardware stores and definitely in Lakeland stores. Spray it on the stains, leave for 20 min and the mould literally dissolves in front of your eyes, try it:thumb::thumb:
  12. cranky
    cranky Funster
    Oct 29, 2012
    422
    495
    essex
    I agree. Dont wet it in the first place:Wink::Rofl1:
  13. Terry
    Terry Funster
    Dec 27, 2007
    10,771
    6,291
    South yorks
    Slats :thumb:eek:r slots :thumb:If you put enough slots its just the same as slats :BigGrin:
    terry
