MotorhomeWifi help ? (1 Viewer)
PAT N PAUL
129
60
retford nottinghamshire
fiat ducato MWB selfbuild
1 year
Well here we are in lovely Wales but can't get my motorhomefun wifi to work. CAN ANYONE HELP PLEASE ?
I had it set up at home ,with password , now first time out I've forgot how to set it up, when I connect up it as my name with a good signal but can't remember how to get onto wifi site to enter my password , I hope this makes sense ?
Regards and thanks in advance
Landyman
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
What sort of system have you got? Is it the Motorhome WiFi iBoost?
PAT N PAUL
PAT N PAUL
129
60
1 year
This is the one
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
I've got a home made booster and it probably uses different addresses and steps to yours but perhaps it might serve as a reminder if I describe what I do.
I open up a browser and enter 192.168.2.1 in the address bar. This then connects to the booster where I have to enter my user name and password. I then go to the wireless tab and get it to scan for networks. I then choose the one I want and connect to it. You then need to connect to the actual wifi network you have logged on to which can vary depending on what you have and what you are using. But on my Android tablet there will be a thing to "sign in to wifi network" which I click on and follow the direction to enter any user name and password given by the campsite. Of course some net works are open and you don't need to do that.
In summary, it is a two step process. Log onto the booster and select the network. Then log into the network you are connected to.
I must emphasise this is what I do with mine - the one you have may be different.
D
Deleted member 29692
Open your browser on whatever device you choose.
In the address bar type 10.20.30.40
Do not type any of the usual things - http or .com or anything like that.
That will take you to the iBoost log in page.
Feb 24, 2013
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
Did someone not bring their instructions? :)
they are maybe only available online o_O been there with other stuff, nothing worse than the recorded BT message while you hold for ever for help when router has failed, telling you all the information I might need will be online :mad:
PAT N PAUL
PAT N PAUL
129
60
1 year
Hi, well managed to get on thanks to the numbers given, the list of available connections came up , but not able to connect to them, must be me doing something wrong, still can't find were I need to put username and password, still no wifi
Thanks for you replys
Regards
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
Regards
You can only connect to networks for which you have the password or number. For example on a campsite. You won't be able to connect to a local business unless it is unprotected, which is unlikely.
What sort of networks can you see?
PAT N PAUL
PAT N PAUL
129
60
1 year
Yes all I can see are campsites , I am with bt fon but unable to see any , so thanks again for your help I'll keep an eye out for any bt fon connections while on my travels
Chris
21,053
278,728
None
10 years
Thread title changed from MotorhomeFun WiFi to MotorhomeWifi
Is MotorhomeFun wifi still under development then Jim?:)
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
You have just come up with the dreaded words, bt fon :( have a look at other threads that are on today.
