Motorhome without water. (1 Viewer)
RonR
5
3
Sheffield
since 2011
I'm about to go on my first trip in a Hymer B544 SL (2008). I picked it up on Tuesday and most of the time since then has been spent learning and cleaning.
My big mistake seems to have been sterilising the water system and worse still using the drain tap to empty the tank.
I can't get the drain fully closed. Has anyone come across this before? and how can I get round this?
DBK
18,009
48,006
Plympton, Devon
PVC, Murvi Morocco
It may be blocked with a bit of crud. Not unknown when descaling boilers as well. You could try putting a hose in the filler, opening the drain tap fully and try and flush it out.
If you can't get it closed it may not be a big job to replace it, depending on access of course.
Another option is open drain and back flush in the hope of dislodging the crud.
Lenny HB
53,321
149,534
On the coast in West Sussex
Hymer B678 DL
If you are talking about the drain tap on the tank operated by the wheel on top of the tank they have 2 positions.
You turn it until it stops this then leaves 20Lt in the tank (traveling allowance) then you have to give it a hard turn and it will clunk past this position to fully drain.
Chipster
1,008
1,119
East Midlands
Getting there!
Unless it's come undone.! Ours did and would not shut off. The lock nut had come loose. Good fun trying to get lock nut tight again with one hand and a pair of pipe grips in the tank!!!
Lenny HB
53,321
149,534
Hymer B678 DL
Our last van if you were over zealous with the knob the operating rod would pop out of the centre joint. That was fun bowing the top of the tank to get back in without dismantling the complete assembly.
R
RonR
5
3
Sheffield
since 2011
Thanks for all the advice. Doesn't look like I'll get a lot of rest this trip.
I'll let you know if and when the tank is water tight again.
R
RonR
5
3
Sheffield
since 2011
I've been reading all the posts again.
Lenny, it is the drain with the little wheel on top of the tank.
I did give it the extra turn and emptied the tank.
I thought I had closed the thing but perhaps it is stuck at 20l.
Chipster
1,008
1,119
East Midlands
Getting there!
Ind
Indeed. One of the barbeque legs used to force the tank top down !!
Lenny HB
53,321
149,534
Hymer B678 DL
Taken a couple of pics for you, one in the closed position and one open. In the 20Lt position it looks the same as closed. The white plug is hollow and I think in the 20Lt position excess water flows down through the plug and there is another valve inside it. From underneath the van when fully closed you will see 2 white prongs sticking down in the 20lt position they are half retracted and fully retracted when fully open.
