yes - made sure I checked them when they arrived! marked Agilis camping / CP etc.
Manufactured in Poland, 2013
Prices are fluctuating - your link to mytyres has £145 today?
£ against the euro?
What size tyres are you looking for?
oh: Ive had my motorhome from new (Sprinter 316 Phantom) it needs new tyres but I read you should but the recommended tyres from the manufactures on which are Conti 225/70/15 which was on the motorhome when I pick it up new (the tyres are standard not motorhome ones )what should I do .I have shopped around and can get standard ones with the grading B,B, and the weight for the axles for £110.37 fitted each :Blush::thumb:HELP PLEASE
oh: Ive had my motorhome from new (Sprinter 316 Phantom) it needs new tyres but I read you should but the recommended tyres from the manufactures on which are Continental 225/70/15 which was on the motorhome when I pick it up new (the tyres are standard not motorhome ones )what should I do .I have shopped around and can get Continental standard ones with the grading B,B, and the weight for the axles for £110.37 fitted each :Blush::thumb:HELP PLEASE
Like you we have had some good prices quoted for certain makes, however, it's just that I am getting conflicting reports and advice from garages around me as to whether I actually need camping tyres on notoh:
I use the van all year round, but before spending the money on two new camping tyres........do I really need them on the van, or could I get two quality non camping tyres that will still do the job without comprising safety etc.
I spoke to one local garage today who deals in hgv/tractor/vans and he said he could give me a quality Goodyear "non camping" tyre that had a higher spec than other quality "camping" tyres.........thus the confusion!
Bill
Can't argue with that , good point well made. All I'm saying is the super dooper camping version may not always be available at the time when you need one and if the alternative is an adequately load rated commercial tyre then it's not actually worth getting in a flap about:thumb:the problem as i see it is that people spend the equivalent of buying a 2 bed flat on their motorhome then quibble about spending an extra £10 - £20 a tyre to buy something designed for the purpose. you cant help some people as their wallet rules their head. bet they will be quick to complain that the handling of the van is off or that the tyres didnt last
i am not being rude or disparaging about owning older cheaper motorhomes. however you should buy what your budget will allow for and if that means fitting commercial van tyres with non reinforced sidewalls then so be it. yours is clearly an older us model, so i understand availability of sizes may be limited and for you the extra capabilities in mud or snow will play a partExcept some didn't spend a 2 bed flat's worth. New tyres for mine (sorely needed due to age, rather than tread) would cost 1/3rd the price I paid for the van if I spent it on overpriced "camping" tyres. I'd rather get M+S all terrain tyres for mine.
I'm thinking of getting 7 Toyo Open Country A/T LT225/75R16 115Q. The heaviest axle requires a 105 rating. I believe you should go for a tyre at least 3 over the minimum required to reduce sidewall damage, even if legally not required. I also believe you need to downrate an additional 3 for dually configuration if not specified by the manufacturer (i.e. a 115 should be considered a 115/112).
Also considering a H/T tyre, for better fuel economy and noise, but the A/T is a good compromise and I never go much over 50mph and have an affinity for muddy fields.
However, compared to a "camper" tyre, these should be pretty robust, MUCH better in mud and snow, easier to find emergency replacement, better looking and much cheaper.
modern motorhomes do benefit from the reinforced camper tyres, and therefore they play a part in making the driving experience more car like. you get less wallowing on cornering and they resist deforming by being parked up for weeks or months on end leading to reduced vibration. its not purely down to load capabilities on the tyres although this is a very important factor to consider
when you cut open a van tyre, the side wall is as thick as a pencil, but a camper tyre is nearly twice that to make it more rigid. advising people that commercial van tyres are just the same is not sensible. camper tyres were developed to cope with the specific application. much like aircraft tyres, they cost more due to volumes sold and the necessary r&d that went into them. why would tyre manufacturers spend millions developing something to do a job that was not necessary?
40% more ? NOT at all
16" Agilis £123
16" Agilis Camping £136
