Motorhome tyres. An idea.
Discussion in 'Tech/Mech General' started by Bartyfixedit, Feb 21, 2015.
  1. Bartyfixedit
    Bartyfixedit Funster
    Jun 11, 2014
    207
    298
    Maidstone Kent
    I have an X 250 PVC which I have converted myself.
    At the moment it has standard van tyres which I have already found rather poor on grass. I also do not have a spare.
    Obviously in an ideal world with an unlimited budget I would go out and buy four winter tyres and four motorhome tyres. My budget is not unlimited and so I have an idea which I thought I would run past you fellows.
    If I start off and buy two good quality four season tyres and put them on the front then that will get me through this summer. Later this year I can then buy two proper winter tyres and put them on the back. Not ideal, but it would get me through next winter as I'm not planning on going anywhere too cold. When funds permit I can then buy another two full winter tyres.
    So my final situation would be that I would run winter tyres on the back all year and alternate winter and all season tyres at the front according to time of year.
    I know that a lot of you run winter tyres all year but I'm planning on towing a car on a trailer. I think towing might well be asking too much of winter tyres in the summer on the front drive wheels, particularly since the van has the 3 L engine.
    Obviously to do this I would have to buy two more wheels, but that would then mean that one of those could be the spare and I would only have to store one road wheel at home.
    What do you all think?
    Cheers,
    David
  2. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    7,208
    7,075
    West Sussex
    I know you should not mix winter tyres but not sure about 4 season tyres, but whatever you you do the tyres with the highest grip for safety reasons should be on the rear. It would be very bad practice if not dangerous to fit 4 season tyres to the front with standard tyres on the rear.
    If you go to Italy they have now brought in laws banning winter tyres in the summer in some areas with very heavy fines.
    • Like it Like it x 2
  3. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,818
    1,032
    Cark, Cumbria
    I only ever fit all season tyres, that way you don't have to think about whether or not you've got the rìght ones on. Buy two for the front! Then later buy two more.
  4. DP_JAY
    Mar 17, 2010
    1,818
    1,032
    Cark, Cumbria
    Why, when It's front wheel drive? The fronts do nearly all the work.
    • Like it Like it x 1
  5. phil1946
    phil1946 Funster
    Apr 21, 2009
    280
    3,896
    East Cowes, PO32 6RU
    I suggest you contact member Brianjojosh who runs his own tyre business, what he does not know could be written on a pin head and he does not bite!
  6. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    3,050
    2,819
    Englishman in Mid Wales
    I've heard about putting best ones on the back as well, but I spose @Brian and Jo are the best to answer this(y)
  7. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    3,050
    2,819
    Snap:) I win:LOL:
  8. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    7,208
    7,075
    West Sussex
    Don't do it is dangerous, new tyres when only changing two should always go on the rear.
  9. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    7,208
    7,075
    West Sussex
    It is all to do with grip and breakaway, there are a few videos on you tube showing what happens it you fit the better tyres to the front it's quite an eye opener.
    Quote from Mitchelin tyre safety advice:
    New tyres to the REAR:
    When replacing just two tyres, Michelin recommends that the new or least
    worn tyres are fitted to the rear axle for improved vehicle control and safety.
    This advice applies to front and rear wheel drive vehicles fitted with the same
    tyre sizes front and rear. Ensure that the tyre inflation pressures are readjusted
    to comply with the vehicle manufacturer’s recommendations.
  10. DP_JAY
    Mar 17, 2010
    1,818
    1,032
    Cark, Cumbria
    Rubbish, they should go on the front.
    The fronts brake and steer and drive on a FWD, why would you want them on the back?
  11. DP_JAY
    Mar 17, 2010
    1,818
    1,032
    Cark, Cumbria
    Ive been fitting my new tyres to the front for 45 years without a problem and shall continue to do so until someone proves it's illegal.
  12. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    7,208
    7,075
    West Sussex
    Just look up tyre safety and advice and you will see why. Far safer on the rear down right dangerous on the front. As for fitting for fitting a high grip 4 season tyre to the front with standard tyre on rear a recipe for disaster.
  13. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    7,208
    7,075
    West Sussex
    It may not be illegal but it is far safer to fit new tyres on the rear.
  14. Bartyfixedit
    Jun 11, 2014
    207
    298
    Maidstone Kent
    Thanks for the input so far. I am aware of the issue with putting new tyres on the back and if I was talking about our family car I would agree. I would also agree for an unconverted van where the rear axle loading can vary quite a lot. On my PVC the axle loading is pretty well equal front to rear.
    In this case I'm talking about 3800 kg of van with tyre pressures of 65 and 73 psi. The ground pressure on this vehicle is so much higher and the likely speeds so much lower than a family car that aquaplaning is far less likely to occur. The tyre industry is making recommendations that are general, we have to decide what compromises we're going to make and how much they will affect us. If my current tyres which are to be left on the back were below 50% tread depth then I wouldn't consider it, in fact the two I would leave on there are almost new.
    Lenny, thanks to the information about Italy, I didn't know that. I shall scrap the idea of using winter tyres then and stick to four season.
    I will have a word with my local tyre fitter, who I've dealt with for years, to check whether or not it is legal to mix two four season tyres with two standard.
    Now to decide which are the best four season tyres. Anyone got any particular recommendations? Size is 215/75 R16 116/114R
    I can see I'm going to have to be looking in the archives:D
    Thanks all,
    David.
  15. Bartyfixedit
    Jun 11, 2014
    207
    298
    Maidstone Kent
    thanks for that Phil, I'll chat to my local bloke first, I never feel comfortable taking the advice from one person and then buying the item elsewhere. Call me old-fashioned:cool:
  16. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    7,208
    7,075
    West Sussex
    To some extent I agree with what you say David, but my concerns would be when driving in snow. With the weight of a Motorhome with a large portion of the weight on the rear, if it breaks away you aren't going to stop it. For the sake of a couple of hundred quids worth of tyres you are risking thousands of pounds worth of van, also their are the insurance implications, if they have a get out from a claim they will use it.
  17. Bartyfixedit
    Jun 11, 2014
    207
    298
    Maidstone Kent
    Have no fear Lenny, I shall have all four as four seasons before I risk snow.
  18. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    800
    651
    Wet and cold place outside of M25
    Uk Tyre businesses have some explaining to do as I have averaged 35,000 miles a year for 40 years. Replacing fronts at anywhere from 10,000 miles to 15,000 miles. Rears at about 25,000 miles. Quite a few tyres ?
    Now That information to swap the rears to the front and put the news on the back has never been even hinted at and that is across many fitters from Plymouth to Aberdeen. NOT ONCE !! :(
    I watched the video and I would like more information eg. just how bad were the rears. :unsure:
  19. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    7,208
    7,075
    West Sussex
    One of our local tyre suppliers who specialise in performance tyres have a large Michelin poster on the wall in the customer waiting area explaining that new tyres should be fitted to the rear when only fitting two tyres.
  20. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    800
    651
    There you go, see up here we are just mushrooms, " Kept in the dark and fed on S$$T". :whistle: :)
