Motorhome Power Supply - Advice Needed
Discussion in 'Motorhome Chat' started by Jeff2008, Jun 28, 2013.
  1. Jeff2008
    Jeff2008 Read Only Funster
    Jun 28, 2013
    4
    Middlesbrough
    Hello there,
    I am a newcomer to Motor homing and need some help.
    On collecting the van there was very little power in the living area. I charged up from our mains supply overnight and following day everything was fine. We went out for the afternoon , using hardly any electric , just had the fridge on for about an hour. Returned home and later in the evening I noticed there was again no electric. Overnight charged it again but this time there was no change and we still have no electrics.
    No problem with the vehicle it drives fine and all electrics there are ok.
    Any advice welcome !
  2. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,958
    23,796
    Narrfoook
    Hi Jeff and welcome to the forum :thumb:
    It SHOULD charge the leisure battery as you drive, but it also sounds as if the leisure battery is pretty much had it I am afrad.
    The fridge should never run off of 12v when the engine is not running.. Either gas or mains, so running a fridge for however long should not discharge the battery
    Do you own a multimeter Jeff ?
    If you do, check the leisure battery voltage without the van running and not on hook up.
    Start the van and check it again.
    If it is exactly the same I would say the leisure battery charging circuit is not very well..
    • Like it Like it x 1
  3. Jeff2008
    Jun 28, 2013
    4
    Middlesbrough
    Did wonder if it might be the leisure battery .Don't have a multi meter but can get hold of one and will follow your advice
  4. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,775
    8,020
    Is this a new or used van ??
    If used then very likely the leisure battery wants to be changed..
    As suggested get a multimeter and test battery if its charging.. If it is and it doesn't keep any charge then replace..
  5. rangitira
    rangitira Funster
    Jun 30, 2010
    6,523
    13,732
    Cornwall
    Sounds like the Battery is rooted:Sad:
  6. Jeff2008
    Jun 28, 2013
    4
    Middlesbrough
    Thanks ! Will have Multi meter tonight so will test battery and go from there.
  7. Jeff2008
    Jun 28, 2013
    4
    Middlesbrough
    Tester battery with a multi meter and the battery is flat. Running the engine doesn't change the reading so it does look like a new battery is required.
    Thanks for the advice folks :Smile:
  8. Jaws
    Sep 26, 2008
    18,958
    23,796
    Narrfoook
    Sorry, but you have more than a flat battery problem there..
    If there is no charge going in to the battery with the engine running ( as you say, no change in the reading ) then you have a major fault in the charging system
    I would personally go right back to the dealer and explain that the van does not charge the battery when the engine is running.. You have only just bought it so they should sort it out for you :thumb:
