Motorhome help!!!!!
Discussion in 'Introduce Yourself' started by Angie mccleary, Apr 7, 2016.
  1. Angie mccleary
    Angie mccleary Read Only Funster
    Apr 5, 2016
    Kinross, Scotland.
    image.jpeg Hi everyone,
    I have a 2004 swift ace Roma Motorhome and I have managed to flatten the battery of it the twice I have been away with it. I have a owners manual and can understand the stuff that's on it but the control panel above the door is the part that I am not sure about.
    Is there any nice people out there that could assist me with what each button does.
    Many thanks.
  2. Fletton
    Fletton Funster
    Oct 19, 2014
    671
    2,635
    Nth East Lincs
    I'm sure that somebody will be along soon .... Who has those panels ..
    I don't...
    However, It'll all work out in the wash... :)
  3. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,907
    3,902
    Corby, Northants
    You are on the right track. First understand how your motorhome works, then understand why things are going wrong!
    I'm not familiar with your set up, so will go no further. However, I'm already considering, without a full understanding of your problems, if solar panels, battery life, charging system etc. could be a contributory factor, or it's simply a wrong selection of switches.
    • Like Like x 1
  4. PP Bear
    PP Bear Funster Life Member
    Apr 5, 2013
    2,207
    6,572
    UK
  5. Dawn B
    Dawn B Funster
    Oct 20, 2013
    5,220
    14,666
    South Norfolk
    Hi & :welcomesign:
  6. lorger
    lorger Funster
    Jul 11, 2008
    6,288
    7,743
    Dumfries
    Don't have these panels but if you look at the one on the left of your pic.
    The switch to the left is up for Vechile battery and down for hab/lesuire battery.
    The gauge in the middle is dual for water and battery I think you press one of the switches and that changes it from battery to water to vice versa.
    The panel on the right red switch looks like a tap so could be water pump and the other one could either be a external light or to switch everything off or on like a mains switch not sure though
  7. dbnosey
    dbnosey Funster
    Jul 21, 2011
    95
    106
    Going off what I can see:-
    The switch left of the meter is for switching between the vehical battery in the off position (that's up) to the leisure habitation battery on position (that's down)
    In either of these switched positions you can test the voltage level of both battery's with the switch on the right of the meter by pressing it into the test position which should return to a neutral position when released.
    If you toggle the switch to the up position I think it will allow you to check the level of water in the on.
    The two small lights above the meter I suspect will light when your waist (grey water tank is 3/4 or full)
    The switches to the right:- The left one is for your water pump (I think)
    The one to the right I think is the warning light.
    I maybe completely wrong but I hope it helps
    Colin
  8. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,138
    3,294
    Rural South West Wales.
    :hiya2: & :welcome3: :):)
  9. davidbaldam
    davidbaldam Funster
    Oct 15, 2012
    3,046
    7,753
    Market Harborough
    Hi and welcome to FUN. (y)
