Motorhome heating
Discussion in 'Motorhome Chat' started by The rehctub, Jan 13, 2015.
  1. The rehctub
    The rehctub Funster
    Sep 20, 2014
    81
    18
    Luton
    Can anyone help with this enquiry
    While having heating on (blown air ) I end up with a dry and sore throat
    Any sensible help would be very much appreciated
  2. icantremember
    icantremember Funster
    Sep 2, 2010
    5,397
    7,498
    Nr Watton in Norfolk
    I think probably just drinking water, little and often, will help.
    Would obviously be even more beneficial with a wee dram added to make it more palatable.
    • Like it Like it x 2
  3. ABZSteve
    ABZSteve Funster
    Jan 8, 2014
    797
    870
    Not here
    Can't help with a remedy but is also a worry of ours once we get the MoHo I know folks on here use alternative heating at night, perhaps a small oil filled radiator. I am sure the more experienced will be along soon to help.
  4. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,288
    16,960
    Liverpool.
    Sensible replies are in short supply at the minute, but I never run heating of any description when in my playpen. I prefer a good quality duvet.
  5. The rehctub
    The rehctub Funster
    Sep 20, 2014
    81
    18
    Luton
    The trouble at the moment is we are on our way down to Spain and ( wa are using diesel rather than expensive electric) the site is charging .48c for 1 kW
    So oil filled rad would work in UK . But I don't think here !!
  6. Badknee
    Badknee Funster
    Aug 25, 2014
    3,790
    16,816
    notloB
    image.jpg We have a wood burning stove at home and always have a coffee pot of water simmering away on the top of it to stop dry eyes, perhaps a saucer of water near a vent might help you? May be worth a try?
    • Like it Like it x 1
  7. Baldeagle7470
    Baldeagle7470 Funster
    Apr 28, 2013
    3,043
    1,518
    Charente,France and Alentejo,Portugal
    To be honest I seldom put my gas powered only blown air on even at a low setting within 15 mins it's enough but of course it doesn't stay warm.
    I have a 500 watt DeLonghi oil filled rad and it's perfectly warm enough,no dry throat and at night if it's chilly just set the thermostat to a low setting to keep the chill off when getting up.
    Small,silent,lightweight I find it the perfect solution.
  8. busby
    busby Funster
    Aug 18, 2011
    3,642
    3,420
    derbys
    Same here but it would be nice to have a warm loo in the middle of the night..BUSBY.
  9. plumber54
    plumber54
    Mar 15, 2014
    23
    6
    loanhead midlothian scotland
    try a bowl of water it helps the air not so dry
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,112
    17,779
    YO11 2BD
    Yep......if possible (spills !) Place a bowl/dish below each air duct.
    the warm blown air passing over the dish will pull a little water vapour into the airflow.
    Works in reverse too if its too warm.
    cool blown air passing over chilled water should cool the air further....some mh aircon systems works by this method.
    And of course you're going to kick the bowl over.....i never said i was foolproof.
  11. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    3,093
    2,951
    Essex
    As Gordon said, electric is very expensive in Spain, so gas would be a much cheaper alternative. And it has been really cold in the mornings, approx 2 degrees :Eeek:
    Like the idea of a good duvet, perhaps a hot water bottle?
  12. bernardfeay
    bernardfeay Funster
    Nov 18, 2009
    581
    831
    Bolton
    I have never had the heating on over night. I do wear my socks and fleecy top and bottom. No matter how cold it is the answer for us is always more clothes.
