Motorhome Graphics
Discussion in 'Motorhome Chat' started by combi, Apr 19, 2012.
  1. combi
    combi Read Only Funster
    Aug 23, 2010
    64
    9
    After reading a previous thread about restyling the MH with new graphics I thought this would be a good idea.
    My question is what is the best way to remove the old stickers and, more importantly, the adhesive. "Don't do it " isn't an option as have already started !!
    Any help would be very much appreciated.
    cakeboy
  2. Popeye
    Popeye Funster
    Sep 5, 2011
    7,810
    17,389
    New Forest
    Hot air gun helps remove them then a product called TAR & GLUE REMOVER available at most accessory shops deals with the residue.
  3. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    Although I agree with the hot air gun theory, they can damage, but a Steam Gun would do far less and still soften the adhesive.
    Then go and see your local graphics company for some wraps....
  4. TheDogMan
    TheDogMan Funster
    Mar 29, 2011
    658
    366
    Rugby UK
    I have always used a hairdryer on vans, I presume with care you could do that on a Motorhome
    Dave
    • Like Like x 1
  5. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Hi CB, hot air gun -held well off- to warm stickers then as already said glue remover:thumb: but if you have a lot sensible use of petrol works great to remove the glue :thumb:
    terry
    • Like Like x 1
  6. darklord
    darklord Read Only Funster
    Apr 28, 2011
    1,241
    1,243
    essex
    It would be interesting to know what people thought of those "wraps" where the van is covered in vinyl graphis, even the bits with no "graphic" on them.Our van had graphics, but when they were removed, the sun had done its work. We are considering a partial respray, but a "wrap" may be better.........or not?
  7. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    You don't have to have Full Wraps....you can just have part and laquer over it ...thats what I will be doing on my Lambretta....
  8. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    Was it Gromett who has just done his van with vinyl wrap?not sure but will try to find it a few weeks back :Wink:
    terry
    edit yep -http://www.motorhomefun.co.uk/motorhome-chat/47326-motorhomes-freshen-up.html
  9. darklord
    Apr 28, 2011
    1,241
    1,243
    essex
    That'll do for me, just need to spend some time now finding someone reliable to do it for me.:thumb:
  10. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,068
    DERBYSHIRE
    If you have stubborn glue to remove:thumb: try WD40 it usually works on hard surfaces
  11. jhorsf
    May 15, 2009
    9,156
    8,068
    DERBYSHIRE
    I think is wrapped not painted
  12. wiljoy
    wiljoy Funster
    May 23, 2008
    860
    947
    Crook, Durham
    Everyone has gathered information about graphics, wraps, vinyl removal etc over the years. I have now signwritten over 24,000 vehicles since 1980 and IF a good vinyl is used then removal can be easily done by either standing the vehicle in the sun to slightly warm them up or a hair dryer on warm, NOT HOT. Excess heat either from steam or a heat gun regenerates the glue and sometimes makes it adhere more. There is no easy way so patience is a must so as not to cause paint or plastic damage. A few months ago a customer of mine purchased a motorhome from a dealer who had tried to remove some graphics. The result was severe blistering of the gelcoat, so keep away from a lot of heat.
    Vehicle wraps are a recent concept and ideal for a reasonable short term fix, possibly 3 years, if a quality film is used. Most quality wrap vinyl is already fitted with a UV laminate which is enough to protect it from the elements but the lifespan is not great. Police wraps normally last about 3 years or so depending on useage like washing and chemicals etc. NEVER varnish a wrap or vinyl as sometimes the vinyl shrinks very slightly causing the varnish to crack. A GOOD vinyl should last as text/logos for upto 15 tears. Most graphics for the leisure industry are the cheapest so fading and cracking happens quickly. We used to manufacture for a motorhome/caravan manufacturer and they demanded good quality vinyl. When they sold out the new owner wanted the cheap and nasty stuff, that is when we ceased supplying them.
    If any member is replacing graphics I would suggest they ask for either 3M or Fasson or a cast material of reput with at least a 15 year guarantee.
