Motorhome charges (1 Viewer)
peter H
1,313
665
Neath, South Wales
Low profile
Nearly 4 years
Just been channel hopping and heard part of an interview talking about the emmission charges in London.
Also stated was that Austria was now vertually a no-go zone for motorhomers particularly as far as the motorways are concerned.
My question is why? What has happened?
peter
peter H
peter H
1,313
665
Neath, South Wales
Low profile
Nearly 4 years
That's not quite what I meant.
I got the impression that if you do go through Austria then it will cost an arm and leg.
Didn't hear all the interview, so may well have stick firmly by the wrong end.
Peter
Phil
226
Herts
10 years
It all depends on the weight of your motorhome. If it is less than 3500kg you pay the same as a car, you can buy a vignette for 10 days or for 2 months and is quite cheap.
If your M/H is over 3500kg then you must get a GO Box and have to pay depending on how many miles you cover using the motorways or expressways. Not all are Toll roads and those that are not are clearly marked ( as well as those that need the vignette ) It is possible to travel through Austria to Italy without using Toll roads.
Look here Link Removed
and here Link Removed
Phil.
6,551
39,652
Ipswich
RV and PVC
30 years
Hi just had a look at on one of the links phil gave, and it seems pretty cheap to use the M/Ways, for a 2 axle RV like mine its €0.13 pence per Km. €13 euro's per 100km doesn't sound to bad to me. No dearer than the French M/Ways, possibly a bit cheaper.
Olley
43,329
49,441
Olley
still works out at about £1 every 10miles. equivelant to around a 20% increase in your fuel bill for large RV. :Eeek: bet you didnt look at it that way:Blush::ROFLMAO:
john.
6,551
39,652
Ipswich
RV and PVC
30 years
Hi papajohn, you don't buy an RV and worry about fuel/running cost's, if you did it would never leave your drive. ::bigsmile:
The logplat link phil has given is out of date, the map of autoroutes is dated 2005, so my €13 per 100km is now over €18 per 100km.
Olley
