Motorhome Battery (1 Viewer)
dac5
28
28
york
peugeot boxer
march 2014
Got up this morning at 6:00 to go to work Ang was going to give me a lift as she wanted the car.
At 6:15 I asked Are you getting up answer no I feel a bit dopy tablets for her bad back last night.
OK I'll take the van...
Would hardly turn over..
So got the jump starter I got for my birthday in February never charged it..
would not start van.
Ang called get dressed quick take me to work. arrived at work.
Phoned Mick. Do me a favour get me a Battery for the van drop it ta my house and I will pay you Monday.
At work today 7 til 7
Saturday 9 til 6
Think it may be the dab radio as I've been trying to tune in the stations without much success.
Also radio turns on without ignition being on is this a good thing or should I re wire it.
thanks
Dean
Jan 26, 2010
577
1,493
Conwy, North Wales
Relay self build
It may be worth your time to charge the battery and have it tested before you go to the expense of a new one? Intelligent battery charger left on whilst van not in use may be a better solution to the same problem in the future?
dac5
dac5
28
28
york
peugeot boxer
march 2014
Last night the battery I removed was a big brute and heavy too. 110 amps
fitted the new one not quite as big 72 amps,
Will the amp difference impact on the running of the van?
The flat battery was caused by me leaving the radio on with the volume turned right down :Doh: as that was the first thing that came on when the new battery was connected.
I took the face plate off the radio so that I won't do that again, I will re wire the radio through the ignition next week.
thanks
Dean
Jun 10, 2011
464
361
Yorkshire (nr. Leeds)
Since 2011 (so a bit of a newbie)
My radio works in the same way so I know just how easy it can be to leave it on.
However, I like to listen to the radio and music whilst parked up so haven't bothered to change it to the ignition.
We just bought all new batteries for this year. Two big leisure batteries and one for the van itself. It wasn't cheap, but at least I know we will be on full power for the next few years - hopefully!
43,320
49,404
thanks
Dean
if the original was 110ah then the replacement should be the same....or very close.
The battery capacity is determined by electrical load requirements.
72ah may not leave enough in reserve for repeated stop/starts if the need arises.......long traffic jams etc.....as its effectively half flat before you use it.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Rewire the radio to the leisure battery then no problem starting.:thumb:
Daifuse
183
310
Milford Haven
c class
Since 2011
Try re-wiring it to the ACC (accessory) position on the ignition switch - that way it's definitely 'OFF' when you remove the key and the ignition isn't 'ON' in the 'ACC' position.
TheBig1
17,619
43,210
the wrong battery is going to cause problems later as not man enough to handle the load of cold starting with glow plugs and then multiple starts.probably lucky to get it to last a year, so not really saving money
