Mot Good News / Bad News (1 Viewer)
Jul 11, 2009
330
764
Basingstoke
Concorde Compact
Since I was 18.... 1996....
Hi all
A week of mixes for me..
My pilote passed it mot !! Not bad for a 1998 with nearly 100,000 miles on it... But ...
Whilst I used it last weekend in the Wye valley with my scouts I thought the clutch was a bit dodgy a couple of times on steep slopes
Asked my garage to check it and they say it is 95% worn but the book time to change is 6.9 hours !
I've told them to go ahead and change it but does the time quoted seem right. They are a down the line sort of place and they were shocked at the book time too and have said if it's less they will charged less.
Anyone else had a clutch chnage on 1998 boxer 1.9 td , how much and how long was it ??
Daniel
DanielFord
3,020
3,086
That sounds like the quote is for full engine out clutch replacement, I am not near my van at the moment, but I imagine it is possible to change the clutch with the engine in situ.
I reckon you'll end up paying much less, have you looked at places like Mr. Clutch?
rapido convert
57
109
knutsford cheshire
A class rapido 996m
since 07
Hi daniel,
I did the clutch and swopped the gearbox myself whilst in a camp site in sitches spain a few years ago, now i am no professional mechanic and i did not have access to air tools or a ramp (i used a trolley jack and axel stands), i started the job at 8am and replaced the clutch ,gearbox and refilled it with oil ready to test drive by 2pm, a very friendly German gent helped me by putting a bellhousing bolt in while i lifted the box into position off my chest.
It is a very strait forward job as there are no crossmembers to remove, i simply unbolted the ns lower ball joint and undid the cv joint takeing the whole driveshaft out. The box then simply unbolts after taking the gearbox mount off, the box then easily seperates.
As i say all done on a field with basic tools that i borrowed.
So in my opinion the 7 hrs quoted is a tad longer than i would expect.
Andy.
Aug 18, 2014
23,772
133,552
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Hi daniel,
Andy.
You didn't rush it did you ?:LOL:
rapido convert
57
109
knutsford cheshire
A class rapido 996m
since 07
Dont let the grass grow,
The second gear syncro gave up in france by the time we reached spain the pyraneese saw the rest of the box off. Having to crash every gear up and down the box, now i am a firm beliver in fate and as luck would have it we passed a spanish scrappie, i sorced a box which oddly was a citroen non turbo type, strapped it to the scooter rack and made for the nearest camp site, the campsite owner drove us to there equivilent of Andrew Page motor factors where i purchased gear oil and a 3 part clutch, the hardest part of the job was sourcing a 46mm socket and bar to undo the drive shaft nut.
As it happens we would have never stayed at sitches if we had not broken down, it is now one of our favorite places, infact we are leaving the uk tomorrow for the same destination, how spooky is that.
Cheers Andy.
43,323
49,428
Factory times can be confusing.
The easiest, but most time consuming, way is engine on floor/bench...which is most likely where 6.9 hours factory time comes from.
Unless things have changed it usually front n/s suspension and driveshaft and engine mount removal, gearbox out under wing, change clutch and reverse procedure to rebuild.
Nov 18, 2011
11,862
42,963
Planet Earth
A van
Over 25 year's
I changed the clutch on my ducato 45min to take engine out 1hre to take gearbox off clean up and replace every thing 1hr 25min to reinstate every thing every thing total time 3 hrs. ten min start to finish
mind you have had a bit of practise taking the vans engine out(y)
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I once changed engine and gearbox in my lunch break using only my knife and fork :)
On a BSA bantam, 4 Wires 1 chain clutch cable and a fuel line three bolts and out, you were hanging around for you had time to eat a sandwich too.
danielf
Jul 11, 2009
330
764
Basingstoke
Concorde Compact
Thanks all for your replies,
it ended up costing £ 600 for the MOT and clutch change. they also changed the main oil seal as well as a main gearbox inout seal were seeping oil.
it back that's the main thing...
Daniel.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Here is that same chap after helping another motorist with his bellhousing bolt. (y)(y) What a popular fellow!. :)
rapido convert
57
109
knutsford cheshire
A class rapido 996m
since 07
I thought he looked familiar . Toot's I seriously pissed myself laughing when I read your reply, as it happens I am pitched between a frog and a Dutch in Spain at the moment we are the only Brits here.
danielf
Jul 11, 2009
330
764
Basingstoke
Concorde Compact
Ditto made me wet my self.
Whilst on way to Wye valley where clutch was going
My french scout leader colleague Asked me when we were nearly there "why do you keep doing nazi like salutes" surely up you don't know that many people. I was of course waving to all the vans coming the other way. ....
Daniel
