MOT failure (1 Viewer)
43,323
49,427
just been checking my kontiki's MOT history online and found this failure.
Reason(s) for refusal to issue Certificate
Nearside Rear Registration plate lamp not working (1.1.5c)
Nearside Front Headlamp aim too low (1.6)
Offside Front Headlamp aim too low (1.6)
Drivers door cannot be opened from inside the vehicle (6.2.1b)
Drivers door cannot be opened from outside the vehicle (6.2.1b)
Front passenger door cannot be opened from inside the vehicle (6.2.1b)
Front passenger door cannot be opened from outside the vehicle (6.2.1b)
now...i know the reason for this fail even though i didnt own it then...
electronic cab door deadbolts !!!!
the ones fitted to mine are remote controlled deadbolts and when de-activated (opened) they will automaticaly relock in 30 seconds unless the ignition is turned on (and off again if needed) and will remain unlocked until the remote is used again.
the previous owner obviously forgot to tell the tester this and if he used the fob thinking it was an immobilizer the doors locked (press again within 30 seconds and it does nothing)......instant MOT fail.
so if anyone has this type of security....dont forget to turn it off when you go for MOT and tell the tester:Doh:
43,323
49,427
How do you do that then???:Smile:
Link Removed
just fill in the box's.....
runs in chrono order but cant remember if its newest first.
also tells you of fails and advisories with details.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Click on the Pecks Hill Garage Add on the right, then click the Vosa logo it will take you there:thumb:
Geo
chatter
3,689
937
cheshire
5th wheel
looks a handy tool for those who are wanting to check a vehicle out that they are considering buying
43,323
49,427
Wonder who was using the testers brain cell that day ::bigsmile:
bit of a giveaway if both doors are un-openable from inside or out innit....especially as he'd already had the doors open:Doh:
but i suppose if he cant open them they are a fail point....no matter why he cant.
the thing with these is they do open a couple of millimeters, as the door comes off the catch, until the door plate hits the bolt.
