More Tosh Or What? Tyres (1 Viewer)
bhs
214
137
Louth
b class
since 2006
replacing tyres all round and taking advice from forum am using metal valves, local garage is fitting for me asked I supply valves with tyres, when I look around I find this on tyre supplier website
How often should I replace my rubber tyre valves?
Once every six months, when changing your tyres.
I shall be afraid to go out on my own soon!
bhs
bhs
214
137
Louth
b class
since 2006
Meant to ask Does the use of metal valves apply to steel rims or just alloys?
bhs
bhs
214
137
Louth
b class
since 2006
Will do Today! (have asked at another brand of tyreshop in Louth and was advised not to bother with metal valves!!)
Dec 12, 2010
5,408
21,553
Cumbria
since 2011
I took metal valves in with me when I was getting the tyres refitted after having the alloys powder coated. There wasn't enough room to get a socket over the nut in the alloy recess, so couldn't fit them. Tyre guy fitted rubber valves and said they do get more problems with metal valves.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Metal valves are OK for tractors and stuff. I wouldn't use them in alloys. :(
Feb 26, 2013
1,653
9,376
Pinar de Campoverde, Spain
Giottiline T60
Since March 2013
I was told the reason for metal valves was because of the higher psi in the tyres compared with a car. I don't know how true that is though.
teensvan99
231
250
Margate
coachbuilt
Always fit metal valves if you are running at 55 psi or higher. Never run our vans on anything less the metal valves.
steve & ann. ---------------- teensvan
Fatwheels
38
35
Sittingbourne
Auto trail scout
I'm a newbie
I refurbish wheels for a living been doing it for nearly 20 years . So a bit of advice if you use metal valves on alloy wheels generally they will start to corrode around the valve hole . I don't know the science around it but think its some thing between ferrous and non ferrous metals reacting to each other.
bhs
bhs
214
137
Louth
b class
since 2006
My rims are steel but i do have an air horn!
bhs
bhs
214
137
Louth
b class
since 2006
Just to finish this post here is the reply I received from Hankook, may help others decidewhat route to take
re your enquiry, concerning tyre size 215/70R15
If the tyre that you have fitted is 215/70R15c 109/107S Hankook LT Vantra (RA18), this tyre is designed for light commercial vehicle application.
The specification of this tyre: 109 = 1030kgs per tyre Single wheel application (2 wheels per axle) at Max air pressure of 65psi
107 =975kgs per tyre Dual wheel application (4 wheels per axle) at Max air pressure of 65psi
S = Speed rating of 112mph
If the tyres are to be used in a campervan/motorhome application, it is strongly recommended that a 10% safety margin reduction is applied to the tyres weight capacity.
Given the axle weights that you have declared are deemed to be accurate that you have checked weighed the vehicle and axles at the operating weights to be used.
Front axle weight of 1650kgs tyre pressures = 56psi
Rear axle weight of 1750kgs tyre pressures = 60psi (2 wheels per axle)
Thank you for contacting Hankook Tyre
