More electrics help please!!!
Discussion in 'The Beginner' started by unitedgirl, Sep 2, 2009.
  1. unitedgirl
    unitedgirl Read Only Funster
    Oct 27, 2008
    26
    spain
    Ok this whole electric thing is driving me CRAZY, I bought 2 MH handbooks read them thoroughly and still dont understand the electric/battery stuff!
    In a nutshell, we were evacuated from our house due to terrible wildfires a few weeks ago and had to move our vehicles (and ourselves) elsewhere for nearly 3 weeks. Our MH (Chausson Welcome 1997 on a Ford Chassis) has been unplugged/unhooked for that time, (we usually have it hooked to up to the house power). We are now back in the house and planning a trip in the MH next week, I plugged back in to the power today, the circuit for the sockets, fridge etc are working but all the lights and control panel etc are not working. Is my leisure battery buggered or does it need to be hooked up a while to re charge??
    Also my leisure battery is in the engine compartment along with the engine battery, however, (please dont laugh) I have no idea which is which, they both look the same except one is 60Ah and one is 70Ah.
    There is what looks like the battery charger located under a rear seat and also have no idea how that works!!
    I am getting so frustrated with this and due to where we live (South East Spain) there are no dealers anywhere nearby where I could go for help.
    Any advice would be much appreciated!!:cry:
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    Hi it sounds like you have a flat possibly dead leisure battery. a simple way to tell which battery is which is to disconnect one at a time. and see which one starts the engine. That one will probabbly have the thickest cables on it. Next check the fluid levels on the batteries, you have been keeping an eye on them haven't you?
    Some vans have a switch that lets you charge either engine or leisure battery, and some automatically charge both. Do do not mention if you were living in the van whilst away for those 3 weeks, if you were and things were ok then maybe the battery just needs charging, but if left flat too long it may well be too late. So
    first identify the Leisure battery
    Check fluid levels
    Recharge with a seperate charger if need be
    check charge state with a hydrometer ( get one from a garage)
    ASAP meet up with some other motorhomers who can help you sort out how the charging system works if you don't have a manual.
    As a last resort, well first as far as I'm concerned send me a plane ticket and I will fly out with my test equipment and sort it out for you, just expences will cover it, hee hee.
  3. madbluemad
    madbluemad Banned
    Jan 26, 2008
    3,341
    243
    spain
    It could be something as simple as a blown fuse on the lighting circut. I cant see a shore line hook up not supplying power to this and everything else in your van.
    Your leasure batteries should only be needed when you are not hooked up.
    Do you have a generator, if so try that, if its the same again it sounds a simple as a fuse.
    From the way that you describe your batteries it sounds as though you have two leisure batteries with your engine battery being somwhere else.
    There are a few good leccy guys on here so I'm sure that you will get the answer.
    Jim
    :Smile:
  4. kenspain
    kenspain Read Only Funster
    May 22, 2009
    272
    If I can help let me know I live not to far from Alicante.
  5. kenspain
    May 22, 2009
    272
    Bring your sun block 36 here today:Cool:
  6. Elvis
    Elvis Read Only Funster
    Jun 13, 2009
    294
    45
    London
    Have you checked your fuses?
  7. unitedgirl
    Oct 27, 2008
    26
    spain
    Thanks guys!!
    I tend to agree that it could be the fuses especially as the lights are not working even when hooked up, now the next question is...are the habitation fuses in the same place as the cab fuses, probably down under the steering column somewhere??
    PS. Wildman, I would swap places with you for a bit of cooler weather, it is just not cooling down here and starting to get on my nerves, especially sweating under the hood of the MH in the blazing sun...hmmm not attractive...:Wink:
  8. madbluemad
    madbluemad Banned
    Jan 26, 2008
    3,341
    243
    spain
    You really need somebody who has the same mh as yourself.
    Typically they are in the drivers side footwell, under the bonnet etc, they try to hide them so its gets you annoyed when trying to find them.
    Be carefull under the bonnet as there could be some high voltage relays there that you need to diconnect the battery to work on safely.
    Do you have email access to the manufacture. They should be able to tell you where they are.
    Jim
    :Smile:
  9. unitedgirl
    Oct 27, 2008
    26
    spain
    Thanks Jim, good advice.
    I have conceeded and have a mechanic chap coming to look at it this afternoon!
  10. madbluemad
    madbluemad Banned
    Jan 26, 2008
    3,341
    243
    spain
    Well done. Lets know what it was when its sorted.
    Jim
    :Smile:
  11. unitedgirl
    Oct 27, 2008
    26
    spain
    Just to say, the mystery is solved, it was both the battery and a fuse!! So now we have a new one of each and all working fine!
    Thanks again everyone.:thumb:
  12. madbluemad
    madbluemad Banned
    Jan 26, 2008
    3,341
    243
    spain
    Hi Unitedgirl
    Glad everything worked out ok
    Jim
    :thumb:
