Moho plumbing help please (1 Viewer)
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
I am taking out the splash back with fold down sink and the mirrored cabinets above to have a go at relining the entire shower washroom area with 3mm bathroom panelling stuff. In conjunction with new shower tray.
I have come to a halt trying to disconnect the two tails from the tap, red and blue that has a black kind of connectors onto the red and blue feeds from the boiler and the cold water tank.
Right the question is how does that connecter come apart ? twist ? pull hard ? cut the sodding thing off and buy new connecter kit ?? :Eeek:
Your help very much appreciated. :Smile:
Oct 20, 2010
2,248
37,616
Burry Port South Wales
Since 2003
If they are speed fit connectors, where the feed pipe enters the connector there will be a ring on the connector slightly protruding, push this ring back into the connector and when it moves just slide the feed pipe out of the connector :thumb:
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
I cut em off and replaced with jubilee clips!!! :thumb:
Terry
11,932
9,068
Lincolnshire
Can't remember ;)
Hi as tremybach says -they will probably be 12mm connecters by John Guest
terry
Moodybrook
Moodybrook
802
651
still in nappies
Thanks very much, they are of course down the back of the panel, not easy to see, or reach. I will have a look in proper daylight tomorrow and see if I can get to grips with your ring of confidence. :Smile:
lorger
9,660
90,500
Dumfries
Knaus Sun 650MEG
If your struggling I'm off work tomorrow so might be of some help if you want a second opinion, just let me know and I'll pop round.
Moodybrook
Moodybrook
802
651
still in nappies
Thanks Gerry, I won't be home till after five, then tea, in to it right after, you are welcome any time then. Not a lot of room to manoeuvre. Waiting for panels and internal corner stuff so just in destruction mode for now.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
[ame="http://www.youtube.com/watch?v=uACaZxaYbUk"]Caravan and motorhome water pipes - part 2 - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=I9rdTgJJzJY"]Caravan and motorhome water pipes - YouTube[/ame]
Have a look here
lorger
9,660
90,500
Dumfries
Knaus Sun 650MEG
I'm going for a run at 5 so won't be home until the back of 7, if your struggling just give us a shout and I'll pop over might not be much help though:ROFLMAO:
I did have to replace the shower tap on my Elddis before so might be same, if its a black connector then mine had a wee ring you pulled into the connector that released the pipe. Not sure if that makes sense to you lol. Just stick your two fingers round the bottom of the connector and pull up. I'm also off Wednesday so feel free to give me a shout.
