Mk 8 transit chausson
Discussion in 'Ford' started by Alonsos, Jun 22, 2016.
  1. Alonsos
    Alonsos
    Feb 9, 2015
    177
    15
    Devon Somerset border
    ive a new mk 8 transit chausson flash 500
    If anyone has this model mk 8 I would be interested to know how your windscreen wiper spindles are sat in the holes , mine come out of the bodywork holes with no apparent seals at all , just approx a 35 mm hole in plastic scuttle plate and & 25 mm approx spindles sticking through no rubber seals as such leaving plenty of room for water to go in ?? Have I seals missing ?? Haven't seen any mk 8 s yet to compare mine with
  2. Alonsos
    Alonsos
    Feb 9, 2015
    177
    15
    Plus in addition each side of scuttle plate where it meets the screen there is a slot maybe 50 mm long allowing water to go into eng bay ( what's that all about )@ first look I thought the scuttle was well designed only noticed this last night when having a detailed look around mk8
    A bit depressed now really mm !
  3. Fenman
    Fenman Funster
    Jul 29, 2014
    666
    1,089
    Correze, France
    Photo would help then I, and others, could compare with Transits we have or drive.
  4. Alonsos
    Alonsos
    Feb 9, 2015
    177
    15
    Ta will do when the bl---y rain stops
  5. Fenman
    Fenman Funster
    Jul 29, 2014
    666
    1,089
    Correze, France
    Rain - what's that.:)
  6. Alonsos
    Alonsos
    Feb 9, 2015
    177
    15
    Pic of wiper spindle hole mentioned above
  7. Alonsos
    Alonsos
    Feb 9, 2015
    177
    15
    Pic of bottom of screen water ingress area drivers side
    • Useful Useful x 1
  8. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,364
    3,798
    Rural South West Wales.
    The drain holes are there for a reason, much like the Fiat / Peugeot / Citroen ( Sevel ) cabs, the scuttle fills with water & without the drains the scuttle would fill & overflow at best & maybe ingress via a dodgy screen seal at worst - whether water draining into the engine bay is a good idea or not, is up for debate.
    The wiper spindles don't look right to me without a seal - but I'm no expert.
  9. Alonsos
    Alonsos
    Feb 9, 2015
    177
    15
    The drain holes are where they should be with hoses under scuttle they work very well , the gaps Ime on about are where scuttle meets screen , water runs down screen through the gaps onto sound deadening material drivers side eng bay now soaked & other side the same route right onto some pretty serious large wiring junctions/connectors not good
    I feel a mod coming on !
    • Like it Like it x 1
  10. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,364
    3,798
    That cannot be right, as it's new I suggest a return to the dealer & demonstrate the issue to them (y)
    • Like it Like it x 2
  11. TG1903
    TG1903 Funster
    Oct 25, 2014
    26
    55
    N.E . Scotland
    Hi , my wipers are the same, if you look at the Transit Forum a few guys have done mods to re route the water running on to the Ecu box
