Missing a spring for the kitchen. Anyone help with a link (1 Viewer)
Nov 3, 2016
881
1,679
Derbyshire, UK
Bailey Autograph
Since 2016
2015 Swift Escape
Kitchen Table extension. One of the supports is missing the spring so does not auto lift.
Anyone able to point me to an eBay link for one?
Thanks in advance
R
Robert Clark
They're only supplied with one spring as standard
Honest - two springs would block the fire escape apparently
davidathomas42
Nov 3, 2016
881
1,679
Derbyshire, UK
Bailey Autograph
Since 2016
You can't easily reach the one nearest the door from inside
That's what the dealer said when we asked
Ok worked it out. As there self lifting with the spring you would need 3 hands to lower it. One to lift the shelf away from the supports and 2 to move the supports out the way while you lower the shelf back down
Fair enough. And at least it's 1 less snag to fix.
Emmit
8,032
17,749
Cornwall
Pilote Explorateur
Jan.2014
You have a PM
43,323
49,427
Believe me, those support struts wouldn't stop me exiting if it was on fire and they certainly won't take the weight of a person in any case.
Why worry about a bit of damage when it's going up in flames anyway.
Any ironmonger will supply a simple spring if you show them the existing one.
Minxy
32,646
66,526
E Yorks
Carthago Compactline
Our Autocruise Accent only had a spring on one with the release on it with the other there just to support the other side, however when I changed the plastic support in our Globecar I put 2 of these metal ones on and both have springs and release clips, if you get the knack you can release them in turn with one hand which is what we do, no need for 2 hands at all.
