scotjimland
- Jul 25, 2007
- 2,250
- 9,764
- A Woosh bang
Hi,
Have you read the instructions as a lot of these oil filled radiators state in their instruction literature that they must not be left unattended, I'm not saying that these particular one's say that but its worth double checking as i would think if anything happened because people hadn't followed the instructions there insurance could be void ???
I returned the one from a well known shop because it contained the clause i mention above, I have since purchased another type which states that it shouldn't be left unattended for long periods, which appears to me to be more acceptable than just "unattended", as in my non-legal mind it allows a possible outlet as how long is a "Long Periods" hope that makes sense.
I must admit i really don't see the point in an Oil-filled radiator that can't be left unattended can any of you explain why some of them state this .
Just thought it may help
Thanks for the alert,
I've triple read the instructions, seven pages on 'how to operate' and there is no mention about leaving unattended, if it did it would be winging it's way back to Makro ,
lots of useful safety tips like , not to be used outdoors, don't place where it might fall into a bath, don't use where petrol or paint is stored.. etc etc
Can you name any of the brands that give this curious advice ? Like you I can see no point in a radiator that needs to be attended ....
Jim
IMPORTANT SAFETY INSTRUCTIONS
PLEASE READ ALL INSTRUCTIONS CAREFULLY BEFORE USING THIS PRODUCT.
Use this heater only as described in this manual. Any other use not recommended by the manufacturer may cause a fire or electrical shock.
When using electrical appliances, basic safety precautions should always be followed:
1. Before operating the heater remove the unit from its packaging and
check it is in good condition.
2. The surfaces of this heater are hot whilst in operation. Always allow a
cool down period before moving it to another location. Keep all
flammable materials well away from the heater.
3. Keep flammable materials, such as furniture, pillows, bedding, papers, clothes, and curtains at least 3 feet (0.9m) from the front of the heater and the sides and rear.
4. Extreme caution is necessary when any heater is used by or near children
or pets and whenever the heater is left operating and unattended.
5. Always unplug heater when not in use.
6. Do not operate any heater with a damaged cord or plug, after the heater
malfunctions, has been dropped or damaged in any manner. Return the
heater to an authorised service facility for examination and repair.
7. Do not use outdoors. It is not intended for use in wet or damp locations.
Never locate heater where it may fall into a bathtub or other water container.
8. Do not run cord under carpeting. Do not cover cord with rugs or
runners. Arrange cord away from an area where it may be tripped
over. Do not use this heater with a programmer, timer or any other device that switches the heater on automatically, since a fire risk exists if the heater is covered or positioned incorrectly.
9. To disconnect heater, turn switches to the off position and remove plug from the power socket. Pull only by the plug. Never pull on the cord.
10. Do not place the heater on soft surfaces. Always place on a flat level surface.
11. Do not use it in areas where petrol, paint, or flammable liquids are used or stored.
12. Do not let children play with the packaging, for example plastic bags.
13. Check household voltage to ensure it matches the rating plate specification.
14. Avoid the use of an extension cord as it could overheat and cause a fire.
15. This heater is filled with a precise quantity of special oil. Repairs requiring
the opening of the oil container are only to be made by the manufacturer or a qualified service engineer, who should be contacted if there is any leakage.
Instructions for PORCYPE - 7
Clause 4 says to use extreme caution.. common sense would say that would apply to any heater
Used to use a Redring tubular greenhouse heater in the toilet of our Landau.
Bought it from RS supplies for about 15 quid I think.
At 1200mm long, it fitted nicely on the back wall on its mounting brackets and at onlt 40 watts it was enough to warm the bathroom without hammering the hook up.
I should add, we NEVER leave any heating on when leaving the coach unattended, apart from the inherent danger posed by the heaters there is also the risk of an electrical fault developing in the coach wiring causing a fire..
Good idea, safer and as you say not hammering the supply but I doubt if 40watt would keep my OH happy .. she likes it like a sauna ..
Excellent as frost protection :thumb:
Hi, Jim
The one I have at the moment has frost protection and a Overheat cut-out they also make one with a built in timer so some of them must be made to leave on when unattended, I have read the paragraph you state below regarding dangers from all heaters, but surely if they are fitted with the devices mentioned that should be all the protection one should need, or isn't it ? it does make you think oh:oh:
