Milenco Triple/Quatro (1 Viewer)
Heyupluv
3,862
1,593
France,
touring many years..42+
Does any body have any of these ramps Milenco Triple...and the Milenco Quattro....if possible could you measure one of both type's to answer my question.....Please
One Advert says on the Quattro
4 stages with total height of 200mm and 160mm on the top 4th stage.
Another advert for the Triple said
3 stages with a 160mm on the top stage...:Doh:?????...Are they saying they are the same total height :winky: ...BUT the Quattro has more height options.....and longer
Could you measure ...please..... the top stage lowest part what the tyre sits on.... to the base please. and say if it was the 3 or 4 you measured thank you
Also what are your opinions of them.
Sorry to be a pain.... but I am now about to disregard my yellow Fiamma 100mm
Mel:thumb:
11,470
25,061
South Wales
Coach built Adria
Hi, good questions, i have the triple :thumb: and when its stops "persisting it down" :Eeek: i will go and measure for you.
so far have been pleased with the triple. but did consider the quatro but cant remember why i rejected it when i was stood looking at both... ( I guess thats an age thing!! ) :Doh:
it may have been price, size, or they are the same final height!
thats why i say " good questions" i now also want to know the answers.
get back to u soon:thumb:
May 8, 2011
3,834
47,991
God's county. Helmsley, North Yorkshire.
IH Tio 630 RL
Since April 1846 but have always camped.
I have the triples and if it ever stops raining I'll go and measure them. I had the yellow fiamma ones before and these milenco ones are much better.
Cheers.
May 8, 2011
3,834
47,991
IH Tio 630 RL
Phil, you're right it's just stopped!
Now, to the centre of the third bit measures 120. To the very end bit is 160 so I guess that is what milenco is quoting.
Hope that helps.
Paul
golly
2,001
69,093
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
Hi, I have the quatro version, just measured, to centre of top position is 155mm the very end measures 195mm. They are heavy and large but I have a Transit based hobby which is naturally "nose down" and I found the Fiamma ones just were not tall enough at times.
Dec 7, 2009
307
295
Macclesfield
Knaus Sun Ti
Since Dec 2009
We ended up with the triple - rejected the quatro on weight and size.
So far they have been adequate for every slope encountered :thumb:
Sorry - can't measure as they are in the van in storage!
Heyupluv
Heyupluv
3,862
1,593
France,
Thanks Phil ...I await your answer:thumb:
Heyupluv
Heyupluv
3,862
1,593
France,
Cheers.
Thanks ...Nirvanauk...:thumb:
Heyupluv
Heyupluv
3,862
1,593
France,
Hope that helps.
Paul
Thank you Nirvanauk...and Phil.....it looks like the Quattro are higher then....160 and 200 to the very end bit
Mel
May 7, 2011
4,797
42,785
Cornwall Gorran Haven
T Line 785
motorhoming since 1979
Hi Mel, I have got a pair of quattro's personally I love them ,I also take 1 fiamma yellow wedge just to level the third wheel and have always got level. They are a bit bulky but worth it. Thanks for email about the aire the other day. Still trying to talk wife into going back to france for more hols , but after me being took poorly while in the loire shortly after we met you at catillon sur sambre, she's now nervous as she doesn't speak french and also doesn't drive ( then she would feel stranded if the worst happen ) Terry:Cool:
Heyupluv
Heyupluv
3,862
1,593
France,
Thanks Terry:thumb:....
Sorry to hear you took bad down in the Loire area..but I do understand
We have a new Aire in the Dunkirque:winky::winky: but we need to try it out first...very soon although not the best time of year in France to test any new Aire out
Mel
Heyupluv
Heyupluv
3,862
1,593
France,
Yes that is the problem with the Rapido... nose down..low ground clearance...built for speed:winky::winky::ROFLMAO::ROFLMAO:
Yes the Fiamma are a little on the low side sometimes.
I do like your Avatar.....are you Dave's... Shifty...Shifftzz.....Twin Brother as your Photo and his look very much alike...except for the glasses you have on for the upper class of course:winky::winky::ROFLMAO::ROFLMAO: the reflection of the lady taking your photo is it the Wife...
golly
2,001
69,093
HYMERCAR PVC
since August 2009
Must be a distant Welsh cousin, The reflexion, yes thats my child bride:ROFLMAO: but for Gods sake don't tell the wife.:Eeek:
GJH
29,450
38,828
None, now sold
2006 to 2022
We bought a set of Quattros at Stratford show, having compared them to the Triples and decided that they gave more options. On the one occasion we've used them we found that having one front wheel on the 4th step of one and the other front wheel on the lower step of the other (rather than using a single ramp with wheel on the third step) gave us the best level for the way the ground was. Rather more versatile than the yellow Fiamma ones we used with our previous van.
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Hi, rather like a previous poster (Graham I think) I use the quattros.
I can sit up on the third level with no fear of toppeling off, I also carry a small fiamma wedge for the third wheel.
I have on one occasion (Metz) sat on the top of the quattro with the opposite wheel on the first step.
A far greater range of heights offering a more versatile levelling solution.
I'm sure they are heavier and larger but they are NOT heavy or indeed too large.
:thumb:
Dec 6, 2011
11,470
25,061
South Wales
Coach built Adria
Ok its stoped raining :thumb: enough to get the tape out. i know you have had lots of good reply's already. here's my bit;;
overall lenght 600mm
with 300mm
step 1 40mm
step 2 80mm
step 3 120mm
total hiegth at end 160mm.
as already mentioned they are better than the Fiamma models because they are wider and have a flat base plate which does not sink into the ground as much as a Fiamma.
lorger
9,632
90,364
Dumfries
Knaus Sun 650MEG
We had some friends from Slovenia stay a few nights in their mh at ours last week and they had the quattros, first time i had seen them and very impressed as he got level no problem
Thinking of getting a set myself
Jaws
23,821
71,977
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
After crushing 2 sets of the yellow Fiama type we went for the Milenko.. got the Quatro ones as like others, the Miller is nose down and so far, three years on, we have been repeatedly grateful for the extra height !! :thumb:
Heyupluv
Heyupluv
3,862
1,593
France,
with 300mm
step 1 40mm
step 2 80mm
step 3 120mm
Thanks' Phill ...you are a treasure....and so precise:thumb.....Mel:
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
i got the thule triple ones as they were cheap but stronger than the fiamma ones.
they have been ok with the weight of my van.
