Milenco Security Hand Rail Frame Mounting Kit
Discussion in 'Motorhome Accessories' started by RogueStorm, Jan 16, 2015.
  1. RogueStorm
    RogueStorm Funster
    Jan 8, 2015
    43
    23
    East Sussex
    I was recently given a Milenco Security Hand Rail as my wife needs an external rail to get in and out of our van. Not having the requisite space inside to bolt it directly to the wall I needed to purchase a Milenco Security Hand Rail Frame Mounting Kit. The kit has three instructions on the box that it came in, there are no other instructions and it looks simple enough;
    1. Bolt the hand rail to the mounting kit - Done that.
    2. Bolt the mounting kit to the frame of the door (including a bit of mastic) - In Limbo
    3. What looks to be two screws/bolts going through the camper body into the mounting kit.
    It's the third instruction that's worrying me as I have no idea where to put those bolts. The Milenco web site has a video where the instructor simply says, sic "As a security touch, there's a final screw that goes in from behind the unit".
    There are no holes in the kit in which to screw these bolts.
    Can anyone help please?
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,950
    I've not fitted a handle but I did fit a Frame Mounting Lock to our van and the fitting of the Frame Mounting Kit looks similar as far as the two main screws go (into the frame).
    Looking at the Fitting Instructions and Instructions for Mounting Kit on the Milenco web site Here, it appears to me that the procedure is:
    1. Bolt the two Frame Kit pieces onto each end of the Security Hand Rail using 4 bolts each.
    2. Screw the complete assembly onto the door frame using two screws at each end as shown into the video.
    3. At each end drill a hole (or two holes? not clear) from the back of the door frame and into the Security Hand Rail base such that screws (self tapping?) can be screwed into the base.
    The video and photos could certainly do with being a bit clearer and it might be worth giving Milenco a ring on 01908 220102 to both check and to suggest more clarity.
  3. RogueStorm
    RogueStorm Funster
    Jan 8, 2015
    43
    23
    East Sussex
    Thanks Graham, I'll give them a call in the morning. Drilling a hole through the campervan wall was not something I anticipated especially as I'd bought the door frame mounting kit. I guess, if the metal of the mounting kit is not too tough it might be feasible but I could think of other ways to do it.
  4. GJH
    Aug 20, 2007
    27,349
    34,950
    The third hole surprises me as well. I used a Frame Lock on our van because the fridge is in the way. I would have to look but I'm not sure there would be room for a third hole for the Security Handle fitting.
  5. RogueStorm
    RogueStorm Funster
    Jan 8, 2015
    43
    23
    East Sussex
    I have about an inch, possibly a little more, between the edge of the door and the fridge so it could work. If your unit is flush with the door then no hope. Put my hat scarf and gloves on and have a look tomorrow morning.
    • Like it Like it x 1
