Milenco Quatro Levellers
Discussion in 'Motorhome Chat' started by Bollard, Jun 18, 2015.
  1. Bollard
    Bollard Read Only Funster
    Aug 4, 2009
    87
    32
    Saltdean, Brighton
    Just ruined my FOURTH SET of Milenco Quatro Levellers. I have tried everything, reversing up, standing start, running start, second gear start but the bottom 6" of gripper starts to sheer off and gets progressively worse until becoming useless after three or four uses. They are supposed to be suitable for up to 8 tons, we are 4 tons. I know some funsters swear by them having no problems at all. I have used Fiama Jumbo and Thule Jumbo levellers no problem but can't get the height. Contacted Milenco with photographs, receipt etc. and they suggested I had rocks and bricks under the levellers when using them which caused the problem! Ridiculous. We only use them on proper pitch surfaces of grass or gravel. Considered a fifth pair and somehow infilling the first 8" with a resin or styrofoam to just below the grip top to re-enforce them. Any sensible suggestions or alternative levellers welcomed!
  2. SandT
    SandT
    Oct 15, 2012
    127
    385
    Malta
    Use ours with no problems and we are 7.5 ton.
    Ours is an automatic so perhaps we don't get the wheel spin that is likely to cause the damage.
    Perhaps a small strip of strong material fixed to the leading edge of the ramp. This will allow the wheel to "hold" the levellers in place as you drive or reverse up.
    Terry
  3. Mikey RV
    Mikey RV Funster
    Mar 7, 2010
    1,163
    3,259
    Devon
    We're 5 ton and have no problem with ours.
  4. robnchris
    robnchris Funster
    Jan 11, 2010
    1,378
    1,767
    Chester
    Never had a problems with them. I always reverse up them makes it so much easier when leaving.
  5. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
    I have several chunks broken off mine & not just the bottom section either
    I wondered if it was to do with tyre tread pattern ( more aggressive tread pattern - more damage)?
    Also had them slip away violently from under the tyre on smooth Tarmac
  6. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,204
    14,152
    Bolsover, Derbyshire
    we are rear wheel drive and 5 tons no problems at all but only used on front wheels, is yours front wheel drive?
  7. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,320
    8,028
    West Norfolk
    Ours are fine, but the little studs on the underside are getting worn from skidding over ice and grit.
    I will put in some small nuts, screws and repair washers to give them more bite on ice.
  8. StefAndDi
    StefAndDi Read Only Funster
    Nov 3, 2014
    414
    941
    Near St. Austell, Cornwall
    My MH is similar to that owned by @DavidG58. I use Milenco Quattros which have a capacity of 8 tons. My motorhome is 5.3 tons, twin rear wheel drive. I have no problems levelling on either front or rear wheels, on grass or hardstanding.
    Very different to my previous experiences with front-wheel-drive motorhomes. At the Great Dorset Steam Fair last year (more mud than the Somme) those of us in FWD vehicles were spinning all the time and 'spitting out' the levellers whereas those using RWD vehicles were driving straight onto their ramps.
    That experience went a long way to deciding the choice of chassis/drive for my current MH.
    Stef.
    • Like it Like it x 3
  9. hilldweller
    Dec 5, 2008
    27,769
    26,857
    Macclesfield
    I noticed a pair recently - wooden - home made I guess and built not to break. Must have been pretty heavy.
  10. Wickolad
    Wickolad Funster
    Sep 10, 2013
    482
    541
    Wickersley
    Mine is 3.5 ton but probably more like 4.5 with the better halfs shoes and outfits :-(, first time I used mine, on a grass pitch I broke some of the bottom sections but do think this was a result of wheel spin on the wet grass. Apart from that they have been great. :)
  11. DP_JAY
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
    Yes
    3.0litre so heavier too
  12. The Dude
    The Dude Funster
    Jan 10, 2013
    2,580
    2,572
    Near Uttoxeter and Crete
    Take your snow chains off first. :D
    • Like it Like it x 2
  13. Nirvanauk
    Nirvanauk Funster
    May 8, 2011
    1,450
    8,172
    God's county. North Yorkshire.
    Only problem I have is going over the top.:LOL:
    • Like it Like it x 1
  14. Popeye
    Popeye Funster
    Sep 5, 2011
    8,001
    18,332
    New Forest
    You have me beat, my last MoHo was 4.25 tonne and I had it four years using the same Millenco Quattros, I still have them, though I've had Hydraulic levelers fitted to the new one. Having said that you could buy a few sets of quattros for the 5k the levelers cost .
  15. Tea Bag
    Tea Bag Funster
    Nov 3, 2013
    1,357
    2,302
    Portugal
    Hi.
    As said above,fasten a piece of off cut carpet to the leading edge,this will hold them in place while you...... "Mount them ?" LOL.Worked for me,however,they were heavy and find that the "Triple" version is better for us on this PVC.
    Tea Bag
  16. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,320
    8,028
    West Norfolk
    Have driven up ours on chains in the past.
    No damage really to report!
  17. Diabalo
    Diabalo Funster
    Oct 14, 2007
    2,009
    397
    Rochester
    I bought a pair of e-bay and broke a bit off just putting them away, perhaps they ain't Kosher Millenco.
  18. Bollard
    Aug 4, 2009
    87
    32
    Saltdean, Brighton
    Good News. Milenco are sending me a new set of Levellers as a goodwill gesture. I will try my 'fill in' theory!
  19. Mickx
    Mickx Funster Life Member
    Feb 12, 2015
    438
    5,574
    Norfolk
    We're also 5 ton and have no problem with ours. Good news on getting another set....
  20. Patty
    Patty Read Only Funster
    Jan 11, 2015
    7
    5
    Oxfordshire
    Never used ours so took them out of the Pugmobile!!
