microwaves low power
Discussion in 'The Beginner' started by jgee, Feb 1, 2010.
  1. jgee
    jgee Read Only Funster
    Dec 21, 2009
    85
    wigan
    the ones i have seen are expensive how low input power is needed does anyone recommend one:Wink:
  2. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    940
    cheshire
    we just use an ordinary microwave, just remember not to use the kettle or something like a hairdryer at the same time.
    The low power ones not only cost a fortune to buy but take longer to heat your stuff as well, in our last van we just converted a cuboard to hold the microwave, but the new van came with a micro fitted. Not tried our new one yet but if it doesnt do as i want when i want as quick as i want it will be removed and replaced.
  3. dpick
    dpick Read Only Funster
    Jun 13, 2009
    32
    Middlesbrough
    I do the same standard microwave, have used it at the same time as TV and lights with no problems.
    dpick
  4. Caztur
    Caztur Funster
    Jan 31, 2009
    348
    146
    Shropshire
    Yes just use a standard one - the input should be on the back; it's like anything else - heaters, kettles, hairdryer or whatever, just don't go over the amperage for the site by trying to run too much at once.
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,120
    17,789
    YO11 2BD
    DITTO....
    the 'made for motorhome' ones are a ripoff, pricewise, and the 12v ones are even worse....dont know for sure as i'd never entertain a 12v one but maybe 50amps or more on full power.
    cant beat a cheap supermarket bargain microwave for the time it gets used.
    mine was £24 at morrisons :Eeek:
  6. oldun
    oldun Read Only Funster
    Mar 23, 2008
    748
    160
    St Neots
    When you buy your cheap microwave for the MH, as we did, look around for the one with the lowest input.
    Also size and weight are often important.
  7. geoff1947
    geoff1947 Read Only Funster
    May 20, 2008
    999
    92
    Plymouth
    microwave
    Bought ours from Comet bog standard for 28 quid. currently on 10 amps here in Spain no problem as long as we are sensible and turn off kettle etc.
    OFF thread Have lost my Pound sign which used to be on the number 3 key Also the " and @ have swopped over. Have I done something to move these.
