Microwave (1 Viewer)
Scaniaman
42
14
bristol
Fiat Ducato
Newbie
Hi can i put a normal household microwave in my camper or does if have to be for motorhome only?
Allan & Loren
1,736
2,630
Leyland, Lancashire
Autotrail Dakota
Since 2014
We've a normal combination microwave/grill/oven in ours as the original one broke and to get the replacement from USA was ridiculous. Took some finding to get the right size as ours is built in but I got ours from argos and had no issues with power.
teensvan99
231
250
Margate
coachbuilt
We fitted a combi microwave from Tescos. Lasted 5 years and sold it still working in the van. Try and get one 800 watt or under. This means it has a start up inrush current of about 1200 watt. This means it should just be ok on a low wattage site. 6amp or above.
Welsh girl
3,658
3,036
Globecar
Since 2004
We have a 700watt one from tesco. I would have liked the combi but was afraid it would be to hot within a cupboard plus the wattage too high for sites abroad.
tonka
10,825
21,514
Cannock, Staffs
A class Burstner 800
Since 2000
If your going on UK campsites then a cheap supermarket household one is fine..
Most over here give you a 16 amp supply.
Problems come when you go to continental sites who only offer a low amp hook up..
TerryDunlea
19
9
Rhyl
A CLASS
Been Towing Caravans for Years , now have a nice Burstner .
I have modified very many microwave ovens in the pursuit of My Business as An Approved Microwave Service Agent for most of the Worldwide Manufacturers . It is fairly simple to modify a dedicated "microwave only "oven , but it is a far different matter when You take into account "Combi Types " which in the main use resistive Oven elements .Most modified Low Power Microwave ovens can usually be operated on a minimal Supply , eg 6A. But You must take into account the much longer heating times .
Apr 22, 2013
911
661
Cotswolds
Bailey Approach 625
Since 2011
Not really, our 800W microwave requires an input of 1250W less than 6Amps, never had a problem anywhere.
funflair
19,303
30,068
Guisborough
MORELO palace
since 2012
Ours is something like a 700w and never had trouble running it on site hook up even abroad but if there was I would just run it off the inverter and then go back to site power, but to be honest if it won't run a microwave it's not worth paying for if you have solar.
Martin
