Michelin tyres
Discussion in 'Tech/Mech General' started by Douglas, Nov 19, 2011.
  1. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    Due to Michelin no longer producing the XC camping tyres I have to change over to the MICHELIN AGILIS CAMPING 8PR 225/70 R15 112Q.
    Unfortunatly I cant find the maximum pressure for this tyre, I know the loading is 1120 KG but that does not help.
    Has anybody found pressure for this tyre? and what does the "Q" on the end mean?
    Doug...
  2. icantremember
    icantremember Funster
    Sep 2, 2010
    5,221
    7,339
    Nr Watton in Norfolk
    Q rated tyres are for max speed of 99 MPH
    I have the Michelin Agilis on my m/h and they are certainly good for 80psi I run my rears.
    Just checked .......mine are 225/75 R16 so will be different to yours
  3. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    i would think its somewhere similar to the XC camping tyre as they are the replacement.
    try the michelin website they should have the info required.
    they also have M&S ratings if they have over a certain amount of tread so they are a better option if travelling abroad in winter.
  4. aba
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    it says on the michelin website front 4.5 Bars rear 5.5 Bars
    but need metallic valves for these pressures:thumb:
  5. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    Your not going to believe this.... but I have just spent the last hour searching the Michelin site for "pressures" and found none, other that to look on the door pillar!!!
    Can you give my the ULR for that page please.
    Doug...
    • Like Like x 1
  6. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,191
    16,660
    Liverpool.
    80 psi seems a lot, What weight is the van ?.
    • Like Like x 1
  7. aba
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    • Like Like x 1
  8. aba
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    i dont think its to do with the weight of the van in reality.
    i think its more to stop the flat spots occurring whilst stood.
    although mine are at around 80psi but on a 5 ton tag so each tyre actually sees well under a ton
  9. icantremember
    Sep 2, 2010
    5,221
    7,339
    I got the tyre pressures for mine by calling Michelin customer services with details of fully laden axle weights (from local weighbridge) and tyres.
    They came back with the recommended pressures and allowable variations for comfort.
    Customer Service Centre for UK and Ireland
    Campbell Road
    Stoke-on-Trent
    ST4 4EY
    Tel:0800 591 859
    e-mail: south-court.reception@uk.michelin.com
    • Like Like x 1
  10. Snowbird
    Apr 24, 2009
    10,191
    16,660
    Liverpool.
    I can recommend Michelin at Stoke, there technical dept is very good. Have had several dealings with them in the past and can only praise them. If Michelin told you to put 80 psi in it must be right. It just seemed a lot to me. I run 3500kgs with 60psi front and 65psi rear. Will ring the Mich on Monday as I could well be under inflated.
  11. motorhomelover
    motorhomelover
    Jul 28, 2010
    1,719
    613
    The world
    if you ask
    P. & B. TYRES (OSWESTRY) LTD
    Brian is on the RVOC site i am sure he will know the right info for your tyre
    sorry i do not have his phone number to hand
  12. icantremember
    Sep 2, 2010
    5,221
    7,339
    You will need your fully loaded axle weights for accurate results
  13. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    Sorry mate, but there are no Pressure infomation on that Page, thats the start were I spent 1 hour looking and found nothing,
    Sorry again, just spotted it. Thanks
    Doug...
