Michelin camping tyres wearing down quickly on front wheels (1 Viewer)
Apr 25, 2014
1,247
5,058
Lancaster
Overhead cab
8 years
In February 2012 we had all the tyres on our 2007 Swift 590 (Fiat Ducato 2.3 base) renewed with Michelin camping tyres. The service this month showed a tread of 9mm on the spare, 8mm on both rear wheels which is fine but 5mm on the near side front and 4mm on the off side front. The wear is even so I don't think the tracking is at fault. This seems excessive as we have only done about 7000 miles since they were fitted and I was hoping to get about 30,000 miles out of them. At this rate we will be lucky to get 14,000 miles out of the front ones.
Lenny HB
53,408
149,870
On the coast in West Sussex
Hymer B678 DL
Sounds a bit excessive, what is your front axle weight? Has anything changed in your loading or driving pattern that could affect the wear. If you use the van in the winter you should be looking at replacing them at 3mm at the latest. Also although you have not done many miles in five years means the van has been standing around a lot so at 5 years old the tyres need replacing now anyway.
funflair
19,334
30,178
Guisborough
MORELO palace
since 2012
Too much wheelspin.
I have a set of Michelin campers on spare wheels that I alternate with the Conti Fourseasons that I run for the winter, I dont know how many exactly but they will have done twice yours most likely and still loads of tread left but we are RWD.
Anyway as Lenny says it will encourage you to change them for some nice new ones.
Martin
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Not terrible for FWD hauling a huge weight with not enough front weight to reduce wheelspin.
Your choice, keep rotating front/back and buy four at a time or buy two or three fronts to one rear.
S
Apr 25, 2014
1,247
5,058
Lancaster
Overhead cab
8 years
Just had a chat with local Michelin agent and like you say he said this is not excessive wear for a FWD 3400kg van.
Going to take it in to have all tyres inspected and will replace front ones later this year. If the walls are alright on the rear ones will leave them for another year as they still have 8mm on them. Thanks for replies.
Oct 29, 2008
5,068
5,944
West Yorkshire
PVC
since 2008
Our Michelin xc camping tyres did around 30K and still looked like new. And thats on a 5000kg FWD motorhome.
KeithChesterfield
528
1,234
Stand Road Chesterfield
Low Profile
Since 2010
I've just had a one year service on my Skoda car and it's taken less than 1mm off the original maximum tread in 7,000 miles.
With a MH there is far less rubber wasted in accelerating or braking than a car, less speed around bends to cause wear and if the tracking is okay then it could be the wrong tyre pressures that are the reason for such a deterioration in tread.
Weigh the MH axles and check with your tyre manufacturers what the pressures should be for the actual weight you have.
And ask a different Michelin agent 'cos what he says doesn't seem like common sense to me - unless you are a speed freak!
Jul 24, 2009
4,330
104,283
South Yorkshire
Since 1999
One other thing, do you tow a trailer or anything as this will drastically reduce the mileage. I know from experience.
Aug 18, 2014
23,765
133,494
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
He must be joking ! My michelins were on the front when I bought it less than 3 years ago & have since done 45k kms (27k miles) & still have 6mm on them. I expect them to do another 10k trip to UK & back before I change them.
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
You obviously haven't followed me then Keith. :D:D:D
Richard.
MikeD
3,936
3,697
London
IH PVC
Since 2012
Our previous motorhome had around 22k miles and the front tyre wear was minimal.
I am a bit of a slow lane plodder and dont try to set any lap records but your wear does seem excessive.
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Now, I'm likely to be vilified food this because at least 2 have said change tyres at 5 years old.
OK, if you are happy with that, fine.
However, I go to my local independent tyre place and they do a full check on the tyres. Now, it would be in their interest to say that they needed to be changed but they checked them and happy with the condition.
However, I decided this year that I'm going to change regardless of any condition. The garage did say there's certainly a good couple of years left in them but I said to change them. They would have been12 years old this year.
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
i just changed the 10 year old Michelin camping tyres that had 14k on them from our MH that we bought , have replaced again with the newer Michelin camping tyres that i have read are a softer compound and will therefor wear faster , but i have yet to do more than 500 miles , so time will tell for me.
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
This might just be me but I get the impression that tyres do not start out with the depth of tread they used to. All product manufacturers seem to be boasting about their 'competitive' prices without mentioning the fact that there are less biscuits in the pack, less cereal in the box, there is less actual product for the same price. At one time I feel sure tyre depths started out deeper than those that one sees now. Also I wonder if the rubber has been downgraded so it wears away faster. Maybe I am imagining it but I wouldn't be surprised.
Wyn
