MH Roofs
Discussion in 'Top Tips & Tricks' started by Bulawayo Lass, Jun 13, 2014.
  1. Bulawayo Lass
    Bulawayo Lass
    Apr 29, 2014
    255
    325
    Mud Island, nr Mudchester
    Following reading elsewhere about roof cleaning..l am aware l have never cleaned CB roof and l worry about the solar not being as efficient due to dirt and just want to clean the roof.
    How many clean their mh roofs and how is it via tall ladders? l don't want to stand on it and worry if l do l may fall through.
  2. landscaper
    landscaper Funster
    Mar 17, 2013
    234
    165
    Devon
    My partner goes on the roof of ours with a brush and cleans it off a couple of times a year. Where the van is stored there are house martins so it becomes very necessary at the end of the summer. We eventually got around to reading the MH instruction manual (as you do!) and discovered that the weight limit on the roof is just twelve and a half stone = just as well that he only weight eleven and a half!!!! Worth checking if your MH has a weight limit in the manual.
  3. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,327
    34,794
    When we bought our first van I already had a set of large stepladders (7 steps plus platform) which were tall enough to enable me to reach the roof. I used to clean it using an extending brush and rinse off the soapy water using a hose.
    After starting to use Onedrywash I found I could reach just over half way across the roof by standing on the ladders so just move round doing a section at a time. Doesn't take long and safe so long as you make sure the ladders are stable.
  4. philw111
    philw111 Funster
    Mar 22, 2009
    602
    509
    Moray Firth
    I always clean ours by standing on the roof. I use a long handled brush and always stand toward the edge, where it is stronger.
    Haven't fallen through yet :thumb:
  5. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,748
    3,252
    Eastbourne East Sussex
    Cleaning the roof is a bit of a job. I do mine using a ladder and pressure washer but thats not a recommendation, it's just that I'm idle.
    Solar panels just clean with car shampoo and leave for the rain to rinse.
  6. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,274
    7,935
    West Norfolk
    15 1/2 stone and haven't damaged our roof yet!:Smile:
  7. durhamahoy
    durhamahoy Funster
    Jun 11, 2012
    241
    114
    Durham
    At 20 stone, don't think this lump will go on our roof...even if we do have a ladder fixed to the back ( never used!!)
    • Like Like x 1
  8. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    768
    634
    Dumfries
  9. DuxDeluxe
    DuxDeluxe Funster Life Member
    Jul 10, 2008
    9,435
    25,431
    Planet Zog
    Good excuse to get Dawn to clean the roof - she weighs less than me
    • Like Like x 1
  10. sedge
    sedge Funster
    Jul 7, 2009
    4,516
    3,926
    Nr Jct 3 M6
    Moodybrook - so do I assume correctly that that photo was taken before Mrs M found out what you were using cushions for or do you never really use black sacks and just said that in case she finds out?
    :Rofl1:
  11. DuxDeluxe
    Jul 10, 2008
    9,435
    25,431
    Planet Zog
    Brilliant, Jenny - you grassed him up good and proper!:thumb:
  12. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    768
    634
    Dumfries
    Jeasus, I thought you were supposed to be a friendly lot. just as well I have thick skin, repeat skin. :Doh:
    • Like Like x 3
  13. GJH
    Aug 20, 2007
    27,327
    34,794
    Looks a nice job and the correct way to work on a Luton. It's perhaps worth pointing, out in case some do not know, that the over cab area (together with areas around roof lights) is weaker than the rest of the roof so one should not stand on it.
  14. Bulawayo Lass
    Bulawayo Lass
    Apr 29, 2014
    255
    325
    Absorbing all info l like the cushion idea will do that. Lost loads weight but wary of standing on it anyway and no l didnt know about the weakest cab points but l think best for me is avoid standing on the roof.
    If chance appears will do it this weekend but if not will update once l have a go :Smile:
    • Like Like x 3
  15. JOHNSTEY
    JOHNSTEY Read Only Funster
    Jan 14, 2011
    438
    314
    Edinburgh
    Think I should send the other half up as she weighs less...well that's my excuse anyway!
    • Like Like x 1
  16. Fermenter
    Fermenter Read Only Funster
    Sep 6, 2012
    104
    15
    Preston
    Clean the roof with extended brush and soapy water, rinse off using a hose. 13.5 stone and roof seems to cope, not sure I do though always terrified getting back onto the ladder.
  17. injebreck99
    injebreck99 Funster
    Dec 5, 2011
    1,162
    1,249
    norfolk
    Get a local valet round to do it while I have a beer!
  18. Zains Pops
    Zains Pops Funster
    Sep 10, 2013
    722
    4,137
    Chelmsford Essex
    Like others I use a padded ladder and a long reach brush to access most areas. The back of the van has a fitted ladder which invites one to climb onto the roof, when you get up there, the roof has a non slip surface, inviting one to take the scary step from ladder to roof. Done it once or twice not a regular occurrence!,to spread my weight I use a section of 18mm ply board about 800x800. Seems to be ok and easier than going on a weight loss diet.
  19. trophychap
    trophychap Funster
    Dec 24, 2009
    705
    4,718
    bedworth warks
    Just use a pair of steps and an extending brush myself, but I do it everytime I clean the van, it seems to lessen the black streaks and the van seems to stay cleaner longer.
    Generally I only use cold water to clean the van via a hose pipe attached to the brush, with the occasional rinse with Fenwicks Bobby Dazzler.
  20. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,171
    16,615
    Liverpool.
    Am constantly up there cleaning the roof. Its stops all the crap running down the sides and keeps the solars working to full efficiency. Apart from that its a good place to hide with a beer.
Similar Threads
  1. Dave and Ginny
    22
    1,061
