meos lcd tv/dvd
Discussion in 'Motorhome Chat' started by jenny and mitch, Dec 1, 2010.
  1. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    1,887
    1,634
    Bungay Suffolk
    Hi folks. Just about made up my mind to opt for a MEOS 15.4" TV of the above type, can anyone tell me if we are about to buy a disaster or a good piece of kit ? ? Cant really justify the AVTEX at an extra 120 squid. Your input will be greatly appreciated. PS the cheapest I have found is £229.
    Thanks Mitch
  2. pablomc
    pablomc Funster Life Member
    Apr 20, 2010
    860
    235
    Durham
    Opinions vary a lot on whether you need a buy a specialist TV.
    Personally bought a 15" standard LCD TV (cost a £100) that takes a regulated 12 volts supply via a transformer from mains. This then enabled me to purchase a 12v regulated cigarette type connection to use when on 12 volts, although in theory I could use this also on hook up.
  3. jenny and mitch
    Sep 16, 2010
    1,887
    1,634
    Bungay Suffolk
    tv
    Pablomc Can your tv be used in your house and is it dvd and how much ?
    Mitch
  4. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    I bought one from ASDA...It's not 12v but then again I will never use the MH without hook up anyway...has a dvd player and cost under £100...bargain
  5. jenny and mitch
    Sep 16, 2010
    1,887
    1,634
    Bungay Suffolk
    tv
    Thanks A-Strange. Want to be able to spend a lot of time in europe free of 240 volt except top up in Aires etc, but thanks
    Mitch
  6. pablomc
    Apr 20, 2010
    860
    235
    Durham
    Yes it is a standard LCD TV with DVD, freeview etc. Cost me £100 from Makro.
    Its a Akura 15.5HD APLDVD150668.
    The main thing to check if buying like this is if the output from the power supply is 12volts.
    I then purchased one of these from marlins to use on 12volts. Just make sure the rating of your chosen TV just not exceed 3 amps to use this adapter. There are other adapters you can purchase with a higher rating.
    Edit to add if you do a quick search you will find various discussions on the subject.
  7. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    Ive had a Meous 20" LCD with DVD Player etc for a couple of years. It runs of 110V or 230V. It plugs into my 12V socket in the MH.
    Ive never had a problem with it, for me its been a great piece of kit.
    We bought our's new from fleabay who do special offers on them every now and again, wedodigital is the other mainstream outlet.
    Sorry but I cant remeber how much it was and I'm not at home to have look.
    As said above there's a lot of debate about which are the best telly's, a lot pf people like the Avtex.
    Jim
    :Smile:
  8. alcorn54
    alcorn54 Read Only Funster
    Nov 21, 2010
    283
    6
    Co Durham
    TV
    [ame="http://www.amazon.co.uk/230v-Multi-Region-Freeview-Record/dp/B001XJG4MU/ref=sr_1_2?s=electronics&ie=UTF8&qid=1291214338&sr=1-2"]Hi[/ame]
    Try this one on Amazon 12V & 240 plus free Veiw and DVD £159.99
    [ame]http://www.amazon.co.uk/230v-Multi-Region-Freeview-Record/dp/B001XJG4MU/ref=sr_1_2?s=electronics&ie=UTF8&qid=1291214338&sr=1-2[/ame]
  9. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    You can buy a voltage regulator for around £30 that will run the tv direct from 12v - no extra power is used, as in inverters, as the LCD tv draws only 12v of power.
    To ensure this, look at the back of the TV/ or transformer box on the power lead. It should say 240i n 12v out.
    Cheaper to replace, and often a bigger screen. Supermarket ones come with dvd and all the computer capabilities of the expensive specific ones.
  10. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    Hi we have a meos good tv no probs . pete:thumb::thumb:
  11. mick noe
    mick noe Funster
    Apr 14, 2009
    615
    520
    near Boston Lincolnshire
    we just bought a cheepy from asda with built dvd player around 100 squid I think. It has a 12v power supply to plug in to mains but I just made up a lead to 12v supply in van (no regulator) worked fine for the past 3years :thumb:
  12. alcorn54
    Nov 21, 2010
    283
    6
    Co Durham
  13. steveclecy
    steveclecy Read Only Funster
    Jun 10, 2009
    885
    582
    Wirral
    We bought the Meos 15.4" TV/DVD player and we are very pleased with it indeed. The picture is crisp and it has a wide viewing angle.
    Steve
  14. jenny and mitch
    Sep 16, 2010
    1,887
    1,634
    Bungay Suffolk
    Tv choice
    HI folks. Just a note to say Ta for all the advice etc re the above. Decided in the end to buy a viual innovations LCD 15.4" TV/DVD 12 volt from "Richer sounds" for £99.99 and paid an extra £ 9.99 for 5 years warranty. It is excellent, but you must be in the same horizontal plane for best picture, but two people sat 6 feet apart can view it very well no probs. Bought a regulated 12 volt supply to run from a fag lighter but will chop of the end and put a twin flat bladed one to go next to the shelf where the tv outlet is.
    Ta much. Mitch
