Mclouis vans - are they warm?
Discussion in 'Motorhome Chat' started by reckless, Oct 18, 2015.
  1. reckless
    reckless Funster
    Sep 11, 2014
    435
    586
    Sussex
    Thinking of changing for a different layout and we've seen a couple of Mclouis vans we like. Any comments on these? It would be newish but not brand new.
    In particular our Swift is very drafty. How do the Mclouis perform for the chill factor, not skiing in the alps, but UK winter and cooler months in western Europe?
  2. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,696
    10,604
    Glasgow
    Our first MH was a McLouis Lagan 2004. The gas fire kept it nice n cosy. Don't know about in the depths of winter as we changed it after only 6 months for a different layout MH.
  3. St piran
    St piran Read Only Funster
    May 22, 2012
    138
    192
    Kettering
    What model Swift do you have and where does the draft come in?
  4. Mi58ck
    Mi58ck Read Only Funster
    Aug 9, 2012
    101
    91
    Worcester
    Our 1st van was mclouis,it was very warm
  5. scotjimland
    Jul 25, 2007
    28,934
    25,589
    Any van will be 'warm' with heating on.. it is the level of insulation that determines the amount of gas used to keep it 'warm'.
    No personal knowledge or experience of the McLouis and not many owners on here, but you see plenty abroad..
    There should be no draughts in a van.. except perhaps in the cab area.. badly fitted cab doors or seals requiring replacing... or heater vents left open .. common to all coach builds and panel vans.. ..
    The fridge has vents but it should be sealed around the sides.. if not it may let flue gasses into the accommodation.
    What you need to ask or look for is whether it is winterised or not.. ie.. are all the water pipes inside the van, is the fresh water tank inside or under slung.. is the grey waste tank insulated.. etc.. has it a double floor..
    Have a look underneath.. if you see exposed waste or fresh water pipes or tanks without insulation.. they will freeze as soon as it drops below zero.
    My Hymer has a double floor, grey tanks are fitted in the void, together with all water and waste pipes..there is also a warm air supply for extreme low temperatures.. the grey waste valve is next to the tank and discharge pipe is sloping down, so no water trap to freeze. A frozen waste pipe is just as inconvenient as a frozen water supply.
    In times past I've had water and waste pipes freeze in caravans that weren't suitable for UK winters.. let alone going to the Alps..
    • Like Like x 3
  6. hoot007
    hoot007 Funster
    Aug 19, 2010
    263
    266
    trawden lancs
    We have a Mclouis Lagan 263 it gets very warm have had no problem in the depth of winter used it all year.
    It is at present for sale.
    • Like Like x 1
  7. reckless
    reckless Funster
    Sep 11, 2014
    435
    586
    Sussex
    @St piran 2010 Sundance 620FB, I've read lots of threads about draft issues. Mainly cab which is much improved with external screens. We've also made insulated pads to go in the skylights at night, they seem to help.
    There's a vent in the hab footwell which was blowing a gale so that's been taped up. It's much better than it was.
    It's not a winterised van and I do feel the cold more than Brian so it's an important consideration.
    Karen
  8. Derbyshire wanderer
    Derbyshire wanderer Funster Life Member
    Mar 30, 2014
    461
    758
    Derbyshire
    I fitted a sponge between the vent and the spray guard which stopped both the draft and the horrible road noise.
    • Like Like x 1
  9. St piran
    May 22, 2012
    138
    192
    Kettering
    Whats the vent for?
  10. reckless
    reckless Funster
    Sep 11, 2014
    435
    586
    Sussex
    Don't know
  11. Derbyshire wanderer
    Mar 30, 2014
    461
    758
    Derbyshire
    Not sure but I always assumed it was just in case of a gas leak as it is the lowest point. That's why I would not block it off completely.
    • Like Like x 1
