Mclouis 690 2001 model
Discussion in 'McLouis' started by Jonybakery, Mar 22, 2010.
  1. Jonybakery
    Jonybakery Read Only Funster
    Mar 13, 2010
    23
    Hi guys,
    Does anyone know if the above van has the following as I am unable to locate them!
    1 DC output sockets
    2 a drainage valve on the fresh water tank
    Thanks very much
    Jon
  2. dellwood33
    dellwood33 Read Only Funster
    Apr 25, 2009
    3,449
    887
    Newcastle
    I had a McLouis 361 and it didn't have a drain facility on the fresh water tank. Had to run water through the pump to the tapa & then it was into the tank through the big red screw cap to soak up any remaining water with a sponge before drying with a cloth.
    My 12 volt socket was in the TV cabinet. :Smile:
  3. Ralph-Dot
    Ralph-Dot Read Only Funster
    Aug 1, 2007
    1,036
    8
    Billingham
    I have a 432 and the drain is a valve next to the water heater. It also had 3 or 4 DC outlets.
    It is the yellow valve, just flip up the handle, if the pump is on you will hear it start (but it will drain without the pump on).
  4. John de Manche
    John de Manche Funster
    Feb 28, 2015
    41
    36
    Basse Normandie France
    Hi Jon,
    I have the same model and like you could not find the drain tap so pumped out through the drain on the water heater. However I have now found a drain tap under the seat opposite the seat containing the water tank.
Similar Threads
  1. Badboo
    19
    286
