Maxview Omnimax (1 Viewer)
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
Broken Link Removed
Whats peoples thoughts on this arial please ??
tonka
10,829
21,524
Cannock, Staffs
A class Burstner 800
Since 2000
Generally not very good... Omni directional so its looking for signals from 360 degrees, one that you can align / move /point is better...
These has been out for years, I used to sell them for trucks and later motorhomes.
Making some cash off them was the only good point :whistle:
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
look like a NO then !!!!!
whats are you people using ??
not fussed about sat TV just a bit of free view running on a 12v/240 cello Tv ??
376
435
Somerset
hymer s820
hya as gellyneck says the status 550 is good.. with a signal strength indicator..we were getting all the English channels on Calais motorhome aire
scotjimland
2,299
9,951
A Woosh bang
Three options..
1. A relatively cheap directional aerial , example ..
http://www.towsure.com/maxview-mobile-touring-uhf-tv-aerial
Pros
* Cost effective
*Good reception in most areas
Cons
* has to be aligned.. takes time to set up
*not as convenient as a fixed roof aerial.
2. A Status 570 pole mounted aerial..
Broken Link Removed
Pros.
* Easy to align from inside the van, with a signal amplifier and strength meter to assist
* Convenient
* Good reception in most areas
Cons
* Relatively expensive
3. Indoor set top aerial
Pros
*Cheap
Cons
* may only work in strong signal areas
*has to sit somewhere in the van.. not always convenient
Directional will always be better than omnidirectional..
