Maxview Crank Up
Discussion in 'TV & Satellite' started by micky drip, Jun 24, 2015.
  1. micky drip
    micky drip Read Only Funster
    Jul 4, 2012
    190
    121
    mid wales
    I suspect that the co-ax feed from the LNB is damaged inside the crank/rotating mechanism of my wind up dish.
    Any of you Funsters got any suggestions on how to repair said cable ?
  2. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    4,020
    9,251
    NW England
    Can you use the existing cable to pull through a new length of cable? I have the same dish on my MH but it's in storage so I can't check the fine detail.
    • Like it Like it x 1
  3. scotjimland
    Jul 25, 2007
    29,048
    25,741
    Suffolk
    I had one on my RV.. and unless they have changed the design, the LNB cable doesn't go thought the crank mechanism, it is routed through a gland in the roof.. as you can see in this photo ..
    [​IMG]
  4. micky drip
    Jul 4, 2012
    190
    121
    mid wales
    seems like a good idea, will try, but there must be a coil inside to allow dish to rotate?
  5. scotjimland
    Jul 25, 2007
    29,048
    25,741
    Suffolk
    can't remember exactly how the cable is routed internally, that photo was 2007.. and the RV is long since sold.. , but don't think there is a coil or anything fancy inside .. probably just a bit of slack cable to allow turning back and forth, .. only way to find out is to have a look see ...
  6. magicsurfbus
    Oct 11, 2010
    4,020
    9,251
    NW England
    The dish can't rotate endlessly - it stops at a certain point then has to go back the other way. That would suggest the linkage may be uncomplicated, like a cable. Don't the installation instructions have an exploded diagram?
  7. micky drip
    Jul 4, 2012
    190
    121
    mid wales
    Have not found installation guide yet, also I am unable to get on roof, can`t reach far side of dish mounting. Were is BOATER?
  8. scotjimland
    Jul 25, 2007
    29,048
    25,741
    Suffolk
    The most likely problem is a bad connection at the LNB .. wet and or broken.. but you will need to find a way onto the roof .. no other way.
  9. Boater
    Boater Funster
    Oct 6, 2010
    72
    29
    Bridgend s.wales
    hi martyn am still here sent you a pm.
  10. artona
    artona
    Jul 31, 2007
    1,480
    690
  11. micky drip
    Jul 4, 2012
    190
    121
    mid wales
    Thanks for the link to maxview.
    Unfortunately I can`t open it just get Gobbledee gook, any ideas?
  12. scotjimland
    Jul 25, 2007
    29,048
    25,741
    Suffolk
    it works ok for me Micky.. but it is just the installation instructions.. doesn't show an exploded view ..
    have you got on the roof yet ?
  13. micky drip
    Jul 4, 2012
    190
    121
    mid wales
    too fat to get thru roof window, waiting till pembrey rock for santas helper
    Thanks to u all. Will let u know the outcome
  14. micky drip
    Jul 4, 2012
    190
    121
    mid wales
    Thanks to you all for your input on my Maaxview problem. My brother in law managed to reach from roof window fitted new LNB and remade F plug... Job Jobbed
