maxiview Remote control DS1 (1 Viewer)
Les
Apr 18, 2008
301
4,051
Seaford
Low Profile
Remote control for Maxiview box not working :Sad: Maxiview have no stock :Sad: not likely to get any :Angry: anyone got a spare if there box has gone wrong otherwise new system for me:cry:any recomended replacement ?
TheBig1
17,604
43,079
check your dodgy remote for dry joints first, it may be easily repairable
43,304
49,293
you may have problems finding the remote code but you could try an 'all in one' tv remote.
to check if the IR is functioning just point the remote at a mobile phones camera...if its working you will see the IR 'bulb' flashing/lit in the phone's screen. (most phones dont have an IR filter)
if it is working it may be the IR receiver is knackered or the codes have been lost.
no code !!!! i believe some 'all in ones' can be programmed by flashing the existing remote at the 'all in one' but you'll need someone with the maxview remote if yours is cabbaged.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
that looks the same as the one i got with my comag sl30 12 receiver from maplins.
Broken Link Removed
Jaws
23,832
72,344
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Yup, the box's are actually the same as the cheap kits available from Aldis and the like..
BUT !!!
the most common problem with remote controls is the transmitting LED breaks away from the circuit board.
Take it apart, and gently rock the LED .. it should not move at all ( unless it has quite long leads which will flex ) A quick dab with a soldering iron on both connections should sort it out for you..
As a by the by, you can check the remote quite easily with either a digital camera of even a mobile fone that has a camera
Turn your camera on. Point the remote at it
In the view finder you will actually see the infrared LED blinking away IF it is working :thumb:
tonka
10,826
21,514
Cannock, Staffs
A class Burstner 800
Since 2000
Most of these type of receivers are all via Comag in Germany..
So look for replacements to the Aldi / Lidl / silvercrest / Maplin branded receivers..
Also as suggested the all in one / universal remotes may do the job..
EVEN poundland could be worth a try !!!
OR.. get one that "learns" borrow an original remote off a fellow motorhomer and program it.
tonka
10,826
21,514
Cannock, Staffs
Since 2000
HERE YA GO...
Broken Link Removed
:thumb:
whoops.... only just seen aba reply... yes that looks like the original one..
43,304
49,293
you could try replacing it with one of these.....
the zenith TV remote
seemed to work pretty well 57 years ago :roflmto:
Les
Les
Apr 18, 2008
301
4,051
Seaford
Low Profile
Thanks guys thats great lots options now :Smile::Smile:
