Max weight of a fiat Ducato
Discussion in 'The Beginner' started by Grownupgapyear, May 21, 2016.
  1. Grownupgapyear
    Grownupgapyear Read Only Funster
    May 21, 2016
    5
    UK
    Hello, my partner and I are having trouble working out from our logbook what the max weight is on our motorhome and we want to know we're driving safe! We have a fiat Ducato compass drifter, 2.8idTD, medium length wheel base, 1999 - to be honest with you we're not sure the logbook that came with the van is even the right logbook for the van! Thanks in advance for any help you can give us!
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    To check the log book ...open the bonnet and look for the small metal plate near the bonnet catch with weights on it.
    At the top is a long series of numbers and letters.
    That is the vin number and should tally with the numbers and letters in the log book.
    Also on the plate are a series of weights, look for the one saying GVW or MAM....probably 3500kg or 3850kg but could be some other number.
    (Ignore the one saying 5500kg.)
    That is the maximum weight of the loaded van.
    Best thing is type ALL the weight numbers here and we can work it out accurately.
    • Useful Useful x 1
  3. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,681
    7,934
    1999 I dont think they put the weight down then and it does not show on a V5. That was a later addition..
    Lift bonnet on look near doors and you should find a weight plate, Should be the one that is from the vehicle converters. ie If it's an Autotrail, look for their plate...
    You need take it to a weighbridge to see what it actually weighs as it is now..
  4. Phillybarbour
    Phillybarbour Read Only Funster
    Feb 2, 2013
    192
    142
    West Lancs
    The VIN plate your looking for has the VIN number on as stated above, plus four weights
    1. Max Weight typically 3500
    2. Max train weight (ie when towing) typically 5500
    3. Max front axle weight typically 1850
    4. Max rear axle weight typically 2000
    Hope that helps you find it, ignore V5 completely.
  5. pappajohn
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    Maybe not on the V5 but definitely on the vin plate.
    The converters plate could be anywhere.
  6. tonka
    Jul 2, 2008
    5,681
    7,934
    :) Yes thats what i meant. Will certainly be a plate... (y)
    • Like it Like it x 1
  7. pappajohn
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    Except to confirm the vehicle and log book tally....the op thinks possibly not.
  8. vwalan
    vwalan Funster
    Sep 23, 2008
    7,677
    3,953
    roche cornwall
  9. Grownupgapyear
    May 21, 2016
    5
    UK
    Thank you so much for the quick replies! If I'm understanding it right it looks like our max weight is 3500kg, which is what we were hoping for so it takes a real load off our minds :)
    • Useful Useful x 1
  10. pappajohn
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    Yes...3500kg MAX weight.
    Also, you cannot exceed either axle weight.
    1 is the front axle
    2 is the rear axle
    the two added together exceed the max weight but its most important is not to exceed 3500kg.
    The number beginning ZFA is your VIN number which must tally with the log book number.
    The plate does look genuine having one pop rivet and one blind rivet.
    • Useful Useful x 1
  11. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,295
    3,737
    walthamstow east london
  12. Allanm
    Allanm Funster
    Jun 30, 2013
    3,261
    4,431
    Cotes d'armor, France
    You could still do with a trip to a weighbridge. You know the maximum vehicle weight, but do you know how much the vehicle actually weighs before you start loading it?
    It's best to have an idea of your vans actual payload so you have a good idea what you can legally carry.
    • Funny Funny x 1
  13. Grownupgapyear
    May 21, 2016
    5
    UK
    we've taken it to a weigh bridge it fully loaded up, with us, fuel, water and gas and we're at 3300 - we're now considering going back to the weigh bridge to try weighing the front and back axles
  14. Geoff and Fiona
    Geoff and Fiona Funster
    Dec 8, 2016
    30
    34
    Bolton
    Very helpful for us as well
    However, although the AL-CO label on our Burstner Ducato shows a weight 0f 3500 Kg my V5 document shows 3700 Kg
    I would prefer to be able to load the Van up to 3700 Kg is it possible to have the AL-CO label or additional label fitted
    to show 3700 Kg ?
  15. SandraL
    SandraL Funster
    Jan 24, 2012
    312
    160
    Somerset
    We have 4 plates.
    First is from fiat
    Second from alko
    Third from hymer
    Fourth from an upgrade
    The latest plate is the one in force.
    If an upgrade, is not from known manufacturer it would be wise to have documentation to back it up.
    V5 should reflect the newest plate.
  16. Geoff and Fiona
    Dec 8, 2016
    30
    34
    Bolton
    Thank you, I have an invoice for air suspension fitted by a previous owner.
    I will contact the installers and see if they can help
  17. SandraL
    SandraL Funster
    Jan 24, 2012
    312
    160
    Somerset
    Can you find the burstner plate?
    If an upgrade as been done after it left burstner factory you will need an approved company to do the paperwork as dvla will only deal with approved companies. It is highly likely that the installer will not be an approved company.
    SV tech are perhaps best known of the dvla approved companies but there are others such as Mr ruffles? There are threads on here regarding this.
    But if your v5 shows 3700kg really all you need is a plate on the van with 3700kg. If it is from burstner job done.
  18. Geoff and Fiona
    Dec 8, 2016
    30
    34
    Bolton
    The air system was supplied and fitted by a company called Gliderite
  19. pappajohn
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    the weight on the V5 would indicate Private light goods vehicle and road tax will be £165pa.
    you also need a C1 category on your driving licence.
    but.....it would appear Alco downplated the van and DVLA were either misinformed or were never told of the downplate by the registering dealer.
  20. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    10,605
    12,024
    E Yorks
