Many thanks now project finished
Discussion in 'Solar Power' started by peterc10, Jun 15, 2014.
  1. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,386
    2,439
    Tunbridge Wells
    Over the last month I have been constantly asking stupid questions and getting clever answers about a DIY Solar panel project. Many thanks to all of you who had the patience to keep answering (politely) and especially to Techno100, who has helped me so much.
    Anyway the job is now finished and I am very pleased with it. I used 2 x 100W panels from here. I paid £185 including delivery for both panels plus 10m of cable and 2 pairs of connectors. Good value and looks a good product. I got this [ame="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=111352186792"]roof gland[/ame], because I thought it was better engineered than the normal ones that are available, and the thing that made me most nervous was the thought of that hole through the roof. :Eeek:
    I used the Schaudt Solar controller so it works through my existing Electrobloc and display panel. Wiring was easy because it had been factory pre-wired between the electrobloc and the wardrobe that I brought the cables into. Just a case of crimping new connectors fitting the controller and plugging in the Schaudt prewired connection cables.
    Decided to add this 2000W (4000W peak) inverter. Quadruple heavy duty cables between it and the batteries came as a bit of a surprise, but it was easy peasy to fit it in the same locker as the Electrobloc and batteries. Tried it using wife's hairdryer (the main reason for getting it ) and it worked a treat. Looks very well built, but only time will tell how well it lasts.
    A very grey day today and yet charging at 3 or 4 watts when needed, so should be good for what I want. Attached are a couple of pictures. When I first got the motorhome the locker with the electrbloc in was used for other things as well. Now I have replaced one smallish battery with 2 large ones plus added the inverter (the big red thing on the left of the picky) and the solar regulator there is not much room for anything else.
    To all of those who are not sure about DIY fitting I would just say that it was easier than I thought. As long as you have reasonable DIY skills, and do plenty of research it should be no problem.
    • Like Like x 9
  2. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,386
    2,439
    Tunbridge Wells
    Sorry but the picture in the middle should just be a link - not sure why it ended up as a picture - but it is the gland I was referring to. :Blush:
  3. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,182
    14,954
    Leeds the one up North
    Nice
    BTW your aerial is facing the wrong way for travelling. The pointed end is for directing at a TV signal and marked/referred to as the front for this purpose only.
    EDIT
    [​IMG]
  4. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,386
    2,439
    Tunbridge Wells
    Thanks Techno. I had seen that warning on the instructions but had trouble understanding the reason. It's a good aerial but the whole thing looks and feels like one low speed clash with a branch will break the plastic casing (and probably bend the aluminium arm) whichever way it was pointing! And those clashes are more likely to happen when I am reversing into a pitch rather than driving along the road (so far 2 nil in that direction :Eeek:)
    I have always thought pointing the way it is is marginally more aerodynamic. And now I have the panels up there I am going to watching for low branches like a hawk!!
