Managing with a single gas bottle (1 Viewer)
steveclecy
880
580
Wirral
Since June 2009
I've only gone and bought myself a Motorhome with a single gas bottle mount! Cannot believe I did not check that out before. I don't think it would have affected my decision, but still annoyed with myself for not even looking!
That said, it will take a 13 kg bottle, and I know that will last me a long time. But how do I manage it without wasting gas? I am thinking a set of digital scales, set to kg. Weigh when I buy and check as I think it is getting low. Or one of those magnetic things that stick on the side and show the internal gas level due to temperature differential?
If only Calor did a gauge, I wouldn't have a problem. Aware of the Gaslow advantages, but expensive to get started.
Any thoughts, anyone?
Steve
Mixter
227
Keighley, West Yorkshire
Now a year - cant believe it!
You say youve a single mount, but is there nowhere you could strap a spare anywhere? Im surprised theres only provision for a single bottle on a van. Just carrying a 'big' one isnt the same as two separate smaller ones.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
stick on plastic temp guages are useless for get it. run until empty then refill with lpg using a propane refill adapter.
steveclecy
steveclecy
880
580
Wirral
Since June 2009
Yes, there are places, but they wouldn't be ventilated. That was a line I was thinking of going down - and may still, but a little concerned about gas safety.
Steve
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Camping Caravaning now 5'ering 49 years
lateral thinking - if it willl take a 13kg calor does it have the height to take 2 x 5kg BP gaslite they stack one on top of the other
craiggs
67
a 13 kg gas will last a long time does your heating run on 240 aswell so when pluged in you only cook on gas also if you only have one bot you will need to partx it for a new one you could make a small locker and vent with a small hose out the bottomonly one hole then but you can get gas from all over now so you can go over the top i have 2 x 13kg and are still on the first one and have youed it for 7 weeks but only to cook on as all the other runs from hookup
steveclecy
steveclecy
880
580
Wirral
Since June 2009
It has an Eberspacher (sp?) space heater which runs from the diesel tank, so the gas only heats the water, cooks and runs the fridge when no mains. I do expect it to last for a very long time. I already have two cylinders, only 6 kg. Interesting idea regarding the two 6kg BP Gas-lites but concerned about availability.
The reason I considered the weighing method was that I could have the one 13 kg bottle, and as it neared empty, then (and only then) take a 6kg bottle as well, only to use until I could replace the 13 kg one. Trouble with that is that eventually both would get close to empty and may end up with no gas at some stage.
Still, some interesting suggestions - thanks.
Steve
scotjimland
2,303
9,966
A Woosh bang
Steve
I would keep the 13kg bottle and carry the smaller 3.9kg bottle .. as you suggested..
Run the 13kg until empty, change over to the small bottle, then replace the 13kg as soon as possible .. keeping the 3.9 as a back up
There is no reliable way of knowing how much gas is left except by weighing .. use bathroom scales or buy a spring balance, Salter do one for gas bottles.
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Steve
BP Gaslite is available at all branches of Homebase nationwide and also at some garages and garden centres - I also understand they are getting a range of stockists sorted in Europe and Ireland - use the link below for more info - I know some people refill these in Spain as the fitting is exactly the same as the Spanish bottles and as you can see the gas level and mark it when it is full it can be filled to the correct level. In the UK we have never had a problem getting a refill
Link Removed
dewaltman
157
49
south wales
a class
5 years , tugging for 27 years
bite the bullet and get gaslow fitted easier than all the other suggestions and no worries about running out of gas here or abroad dont think about cost but convenience and piece of mind you've just spent out probably thousands on a new van whats a few hundred more to not have to worry about how much gas your carrying etc I changed over this year only have 1 bottle and can recommend it
Mandaxxx
170
Wherever we stop.
We got Gaslow, bought it all online and fitted ourselves, mind you he is an engineer!
Best thing to do no worries about the gas now, yes a big layout initially but a big saving everytime you refill. Beats fannying about with different cylinders-do I have enough gas-specially in foul weather!!!!!!:ROFLMAO:
Mixter
227
But, if everyones saying the regular cylinders last ages - and they do, how long is it before you see a return on the gaslow?
Id conceed the 'peace of mind' thing may come into play if you spent half your time abroad, but youd have to be a bit slack set up to be caught running out in the UK, with or without gaslow.
scotjimland
2,303
9,966
A Woosh bang
Good point also LPG isn't universally obtainable .. Spain for example only has a couple of dozen outlets ..
Spain LPG Map
Full timers will see a reasonably quick return, recreational uses will take many years ..
I've also read reports of Gaslow users being refused at LPG filling stations.
For little more you could install a fixed LPG tank with the added bonus of freeing up the gas locker..
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
The Gaslow advantage is not really about saving money when all costs are taken into account. It will take a long time to cover the installation cost with savings made in LPG price. We had a twin system fitted when we bought the van and would definitely do it again (or choose AluGas for a lighter solution - or a fixed tank).
Apart from the simplicity of filling up whenever you like, I cannot get enthusiastic about the prospect of lugging a 13kg cylinder in and out of the locker. They're bloody heavy and I have to accept, that as time progresses, this is something I would want to do less and less.
Philip
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Surely you've got the message by now Gaslow or the aluminium equivalent.
No waste because you top up.
Gaslow has indicator.
Proper job and in the context of MH costs it's really nothing.
Jan 11, 2010
2,746
9,565
Chester
Auto-trail
Well that`s our 13th year & still loving it.
internal gas tank
We bought our motor home which had an internal tank fitted have to say it`s brilliant, easy to fill up no going out in the rain to swap bottles etc.
Ok so you loose part of an underseat locker but as mentioned you gain an outside wet locker.
After 11 weeks use we filled it up with 21 litres. 3 of those weeks use was without EHU.
Not certain how much such a system would cost to fit but for the convenience it`s well worth it. :thumb:
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
:thumb:That's the way to do it :Smile: I have a 40lt tank underneath and my ex-gas locker now holds The Cadac,3 different sized hook-up cables,1x 25mtr hose reel,6 assorted containers of liquids ie.Toilet Blue/windscreen wash etc a fold-up sack trolley and a partridge in a pear tree !!
We filled to 65% (1st fill is often less than 80%) did Carmarthen Show,5 weeks in France,the Bring and Buy and 3 weeks in scotland-I've only put in 20ltrs (just before leaving France) and we are on 60% now. I'll top up when we land at Calais next Tues and then every 4 weeks until we come back Mid Nov-It's just so easy to do diesel and lpg at same time ::bigsmile:
Mike.
