mains electricity (1 Viewer)
mentaliss
654
306
Lancing
C class
I'm in the process of adding some additional 13 amp wall sockets and in the process of doing so I have found that the existing wiring has been installed using 30amp flex cable?? is this normal ???:whatthe:
43,301
49,287
yes it is normal.
domestic PVC T+E cable isnt flexible enough for a mobile installations and will break with vibration.
even commercial/industrial single core cable , which is stranded, is too rigid so flex is the only real solution.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
2.5 takes 27 amps
1.5 takes 19 amps
often circuits are protected by a 10 amp or a 6 amp MCB so realistically 2.5 is overkill
mentaliss
mentaliss
654
306
Lancing
C class
2.5 takes 27 amps
1.5 takes 19 amps
Thanks Techno100, that's what I think after all if I plugged in a normal household electric fire (1000 watts) into the MH circuit this would throw the trip or the campsite's trip , so, would it be OK to use standard 2.5 flex to spur off (adding two more sockets)?.......30amp flex is also a lot more expensive than 2.5
Techno
Jul 28, 2010
15,475
20,756
May 2010
Your hook up cable is only going to carry 16 amps max and is protected
Nothing in your van in total can draw more than that.
2.5 flex is completely fine and you can add as many sockets as you like as it is not possible to exceed the current rating.
mentaliss
mentaliss
654
306
Lancing
C class
yes it is normal.
Thanks pappajohn but I cant see were your coming from are you really saying that 2.5
three core flex cable is not flexible enough ? ...bearing in mind that this type of cable is dominate throughout the house/industry where appliances such as kettles, vacuum cleaners,TV, lawn mowers, saw's, lighting equipment... just to name a few
PS, I have been using my electric extension reel for over twelve years, I whine it out , whine it back isn't that flexibility...sorry perhaps you can enlighten :whatthe:
Techno
Jul 28, 2010
15,475
20,756
May 2010
John is saying flat twin and earth/domestic hard wiring is not suitable. It is hard drawn solid conductors and is not made to accept vibration.
43,301
49,287
Andy has cleared up the misunderstanding. :thumb:
even in a domestic situation we have to securely fix PVC twin/earth cables to the building structure......and houses dont move or vibrate.
the single core i referred to is basically the same stuff, but stranded instead of solid, without the PVC outer sheath.
mentaliss
mentaliss
654
306
Lancing
C class
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
I'm not convinced flexible cable has any great advantage over stranded for motorhomes when most of the accessories used have terminals suitable for solid/stranded cable.
Flexible cable conductor will migrate away from the compression screw in a tunnel terminal and could lead to overheating of the accessory, so, connection units (spurs) have clamp terminals to overcome the problem.
I think the best thing to do, for wiring sockets/lighting switches in a MH, is use flexibles and tin the terminations.
Techno
Jul 28, 2010
15,475
20,756
May 2010
I crimp two conductors into one yellow pin crimp
These are extra long and I cut down to suit
Link Removed
43,301
49,287
all flexible cables should either be soldered or have a crimp-on ferrule fitted to stop that very problem, no matter what the installation....but in the DIY world they seldom do.
mentaliss
mentaliss
654
306
Lancing
C class
absolutely!! I've just fitted to spur boxes..soldered the wire ends first..as I've always done gives the retaining screw something to bite on!
Jan 28, 2008
10,111
18,365
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
not sure about the becker ones but i found cbe 240 stuff to small and there are no earth terminals i just joined the earths with crimps out side of the back boxspurs in particular are difficult to wire well, crimps on spades have to be uninsulated to fit
meanders
Funster - Life Member
2,551
8,289
Ipswich, Suffolk
C class
Since 2004
The advice so far is great. You are probably already aware, but looking at safety first, you do also have to take into account cable runs. Unless you are using H07 or similar, you need to ensure that the flex stays away from anything with a heat source. You must also clip the flex to the something firm if it runs anywhere near anything that might move and trap the flex.
I'm not sure what regulations apply, but ideally you need to maintain a distance between a socket and water such that you cannot touch both simultaneously although our Bessacarr doesn't follow that ex-factory!
Techno
Jul 28, 2010
15,475
20,756
May 2010
Close proximity of water and electric points is not an issue with RCD/RCBO protection.
BUT don't put the light switch inside the shower LOL even if it is only 12 volts
All motorhomes /caravans have 230 volt outlets near the sink
