Main battery going flat (1 Viewer)
Gollom
206
122
Preston, Lancs
Hymer B534 (1994) - Hetty
Since 2014
When I first got Hetty I could leave for 2-3 weeks and she would start "on the button" with no problems at all. Since my stepson wired a plug socket in for me it does not seem to hold charge anymore beyond a few days. Could this be connected? I had assumed that the red charger box I can see not only kept the leisure batteries charged (which seem fine) but also kept the main battery topped up when on mains.
Just coincidence, or could a relay or charger have blown somewhere?
Mar 11, 2013
1,280
1,677
Gillingham
coachbuilt
since 2005
Without more details it would be difficult to know.Was it a mains socket or 12volts? I would suggest going to as was and see what results you get.
Badknee
7,406
411,690
notloB
Vantage Neo
Living the dream.
Yes I'll go along with this but also mention that cold weather takes it's toll on battery power, something like 50% is lost @ zero degrees or something like that.
We have lads on here that are very well up on batteries. (y)
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
My Hymer mains charger whilst on EHU only charges the leisure batteries. I believe most Hymers of this age are the same. A solution might be fitting a 'Battery Master'.
Gollom
Gollom
206
122
Preston, Lancs
Since 2014
Was a mains socket
Hmmmmm. Something like this? https://www.roadpro.co.uk/retail/12...attery-control-products/battery-master-79.htm
Mar 11, 2013
1,280
1,677
Gillingham
coachbuilt
since 2005
Check breakers and security of connections within the disturbed wiring .check for continuity of wires. No disrespects but how compitant is your stepson?
Gollom
Gollom
206
122
Preston, Lancs
Since 2014
None taken. Fairly newly qualified but the wiring colours caused a lot of confusion at first as they seemed to be a German specs, so he read up on the standards (someone on here was kind enough to give guidance. Due MOT very shortly so I'll get an auto-electrician to take a look
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
Not the one I was thinking of. Mine is rated at 4 amps rather than the device sold by Roadpro which is only 2 amps. I bought it on eBay. The following is the link for the device being sold in Italy but occassionaly you see them from a UK supplier.
Broken Link Removed
