Magnet
Discussion in 'Tech/Mech General' started by martyn, Jan 26, 2008.
  1. martyn
    martyn Read Only Funster
    Aug 31, 2007
    337
    24
    Chelmsford,Essex
    What i would like some advice on is, where can i buy a magnet that picks up brass.On removing the toilet in the R.V. one of the securing bolts dropped down (the black hole).After buying magnets of various shapes and sizes,i find that they do not pick up brass, which the bolt is. I managed to get it below the hole,tried sticky tape and everything,no good.Tried to coax it on to a flat piece of metal,to lift it up,i coughed,the torch shot out of my mouth like a missile,hit the hand i was holding the coaxing stick in,and the bolt disappeared again,so i need a magnet that will pick up brass, any ideas? Thanks in anticipation.:Sad::cry:
  2. Adria 5
    Adria 5 Read Only Funster
    Jul 23, 2007
    1,197
    4
    hi try a stick with a lump off grease on to pick it out . we used this on tankers if we dropped the pot key when we used to top load:Doh:
    RAY
  3. Munchie
    Munchie Funster Life Member
    Jul 28, 2007
    8,575
    11,762
    Champagnac-La-Riviere
    Que?
  4. martyn
    Aug 31, 2007
    337
    24
    Chelmsford,Essex
    Cheers Ray, thats no good now, it's disappeared out of sight,i need a magnet to swing round in there.Think it might have to stay there :Smile:
  5. moandick
    moandick Read Only Funster
    Jul 28, 2007
    1,318
    112
    Landrake, Cornwall
    Or you could try one of those gadgets that are supposed to help you pick a bolt out of the oil sump - a long flexible metal wire 'thingy' with a plunger at one end which operates a three legged 'grab' at the other end. Used to be able to pick them up quite cheaply at most motor spares stockists.
  6. martyn
    Aug 31, 2007
    337
    24
    Chelmsford,Essex
    Thanks Dick, but i can't even see the bolt now,could be anywhere !!:thumb:
  7. Lindy-C
    Lindy-C Deleted User
    For cryin' out loud Martyn..............just get a new flippin' bolt :Rofl1: :Rofl1: :Rofl1:
    What make/model is your loo?
  8. martyn
    Aug 31, 2007
    337
    24
    Chelmsford,Essex
    Hiya Champ,it's not the bolt i'm worried about.It's what might happen if things get clogged up down there,you know what i mean? I know you provide a fantastic service, what size are your hands?:Rofl1::Rofl1:
  9. Lindy-C
    Very small but I aint offering to get 'em dirty :Rofl1:
    I doubt it'll clog anything.....leave nature to take its course and then don your marigolds and do what you do when the dog swallows your front door key :Wink: Wouldn't advise using a macerator though :Wink: :Rofl1: :Rofl1:
  10. martyn
    Aug 31, 2007
    337
    24
    Chelmsford,Essex
    Ain't got a dog or a macerator,think i'll let wifey sort this one out.She was the one that broke the bog in the first place.:Rofl1::Rofl1:
  11. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,039
    8,018
    Forest of Dean
    Hi Martyn
    Sorry to be the bearer of bad news but magnets only pick up ferrous metals and your brass bolt is non ferrous so no chance I'm afraid. The lump of grease on the end of a piece of wire is a good trick and been used succesfully many times, make sure its a really thick black grease.
  12. martyn
    Aug 31, 2007
    337
    24
    Chelmsford,Essex
    Thanks Ror,I think i'll just leave it where it is,if i get any problems i'll send SWMBO down the bilges to investigate.:thumb:
  13. moandick
    Jul 28, 2007
    1,318
    112
    Landrake, Cornwall
    Do you think it will pass through - in the natural way of thinking? :Eeek:
    Shouldn't try the macerator for a while, if I was you. :Eek!:
  14. Lindy-C
    There is of course another way..........the James Herriot approach:
    Remove the sewer valve from the outside of the tank..........remove your shirt........soap your arm up to the shoulder............lie on the ground and shove your arm through the hole and into the black tank :BigGrin:
    Always worked on the telly :Rofl1: :Rofl1: :Rofl1: :Rofl1:
  15. martyn
    Aug 31, 2007
    337
    24
    Chelmsford,Essex
    Yeah right, it's about 8ft. from the valve to the tank,do you think they will give me an arm extension,in hospital next week,if i ask them nicely?:Wink::Rofl1:
  16. Lindy-C
    Tell 'em you're from Eastern Europe and here on a work visa......they'll do ANYTHING for you :Rofl1: :Rofl1: :Rofl1: :Rofl1:
  17. Road Runner
    Road Runner Read Only Funster
    Jul 26, 2007
    14,196
    1,459
    Europe
    You could wait till someone invents a brass magnet Martyn or develop one yourself, think of all the dosh you could earn from your invention and Ror could market it for you with his connections:Wink::Laughing::Laughing:
    You'd really be worth a lot of BRA$$ then:Laughing:
  18. martyn
    Aug 31, 2007
    337
    24
    Chelmsford,Essex
    Don't get me started :Rofl1:where have i heard that before?:Wink:
  19. ruffingitsmoothly
    ruffingitsmoothly Read Only Funster
    Jan 2, 2008
    1,395
    69
    West of Southampton edge
    Hi Martyn
    Can you just fill the tank with water and then let it drain out on the ground (I presume the tank is empty that is!)
    Regards Pat
  20. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,351
    1,439
    Suffolk
    Have you a friend with an aqa vac???? don't tell them why you want to borrow it though:Rofl1:
    Nigel
