Lpg tanks
Discussion in 'Tech/Mech General' started by Norman Jones, Mar 21, 2016.
  1. Norman Jones
    Norman Jones Funster
    Jan 13, 2015
    78
    42
    Nr Aberystwyth
    Gaslow is great, but I wonder...does anyone make a rectangular log tank that fits in the usual cabinet?
  2. mickyc
    mickyc Read Only Funster
    Nov 30, 2009
    566
    2,015
    Spain/Portugal
    It's very rare to see a pressure vessel anything other than "round"
  3. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,176
    3,014
    Kendal, Cumbria
    That's cos square ones become round once filled :D.
    • Funny Funny x 6
  4. mickyc
    Nov 30, 2009
    566
    2,015
    Spain/Portugal
    Correct (y)
    Or at least, they try to :)
  5. maxi77
    maxi77 Funster
    Mar 20, 2013
    324
    181
    Kingdom of Fife
  6. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,176
    3,014
    Kendal, Cumbria
    A friend of mine supports his son who has been racing hovercraft for the past 25 years. By 'supports' I mean he does most of the engineering required to fit the engines, exhausts, ducts, and fans, to the basic GRP moulding. The engines are usually tuned two-stroke snowmobile engines of up to 900cc - most are triples. He has gained a reputation in the Hovercraft Club for making various bits - some of which are expansion chamber exhausts. He makes these from two sheets of flat 1mm steel cut to contorted shapes then edge welded. He inflates this totally flat assembly using hydraulic pressure from a hand-pump. Normally required pressure is 700psi at which the exhaust assumes a round cross-section with the various diameters and bends needed. The final operation is to dress the welded seams with a panel beating hammer. With the pressure locked for this operation it is like hitting a solid steel object and allows the weld (and the inverted crease alongside it) to be beaten out. Pressurised fluid is very, very solid.
  7. Enword
    Enword Funster
    May 20, 2014
    797
    2,699
    Devon
    Hydroforming
