LPG Query (1 Viewer)
Abacist
3,709
10,471
Devon
N & B Arto 88F Tag
since 2013
Before converting to LPG I am just wondering if the bulk LPG that you fill up from in petrol stations is Butane or Propane?
Looking to use it for fridge, cooking and heating not as a road fuel.
Would prefer it to be Propane due to better performance in the winter.
Sorry if this is a very basic question but not found an obvious answer as I get the impression that it could be either.
Raindance1
32
30
Somerset
Phew! That's a relief because I've just had it fitted to my van and hadn't thought of it.
Oct 1, 2013
7,499
19,902
Lanzarote
Nil by mouth
Lots
LPG is Liquid Propane Gas. The answer is in the name :)
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Propane in the UK but beware if you fill up in southern France or some other 'Latin' countries where the butane component of the mix is much higher. Then you could have problems if using the same fill-up during cold weather back in the UK.
Abacist
Abacist
3,709
10,471
Devon
N & B Arto 88F Tag
since 2013
Thanks everyone for the very useful replies
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Actually in UK it is autogas that is mainly Propane.
LPG as sold by the likes of calor can be completely propane (red bottle)
or completely butane (blue bottle) :p
In France Gaz de pétrole liquéfié
In Spain Gas licuado de petróleo
Italy Gas di petrolio liquefatto
Germany Flüssiggas
Aminthule
60
16
Cornwall
Hymer Exsis T564
Since July 2015
So, it can be Propane or Butane or a mix of the two? That presumably means the two are effectively interchangeable and work with fridges, cookers and heaters safely?
Ye, I'm new to all of this!
43,293
49,250
Germany Flüssiggas
Autogas is a generic brand name in the same way Hoover is synonymous with vacuum cleaners......the gas is LPG....Liquid Petrolium Gas
makems
3,438
27,692
Ingleby Barwick,,Teesside
Sadly had to give up
According to the manual for the Dometic fridge I have just been having issue with, it will run on either propane or butane. If using LPG/auto gas it says the burner needs cleaning more regularly (2 - 3 times a year)
Having just cleaned mine and seen how much crap comes out of it I agree that regular cleaning is necessary ( see this thread for the gory details http://www.motorhomefun.co.uk/forum...working-in-morocco.102582/page-2#post-1308931)
I presume this is because Autogas contains additives to make it work properly in car engines that don't combust properLy in a fridge (but that's just a guess)
43,293
49,250
When LPG is used to fuel internal combustion engines, it is often referred to as Autogas. It has been used since the 1940s as an alternative fuel for spark ignition engines. More recently, it has also been used in diesel engines. Its advantage is that it is non-toxic, non-corrosive and free of tetra-ethyl lead or any additives. It burns more cleanly than petrol or diesel and it is especially free of the particulates from the latter.
