Lpg Help Urgent! Spain
Discussion in 'Spain' started by RebeccaKristy, Jul 8, 2015.
  1. RebeccaKristy
    RebeccaKristy
    Jan 27, 2015
    59
    16
    Cornwall
    Help urgently needed. At great expense I converted the gas to gas-it bottles. Only life got in the way, and when we've arrived at santander we have forgotten to get the adapters. We went to one lpg garage and they couldn't help, I don't think they have the english adapters.
    We are back past Santander tomorrow. Does anyone know of a garage which has the adapters, for sale or to borrow? Or any camping shops here that sell them? We are running low on gas now! Thank you.
  2. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,575
    7,152
    Plymouth
  3. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,783
    13,655
    Norfolk
    Repsol stations that have autogas normally have the necessary adapter to fit their pump nozzles but they will only screw in the standard uk autogas filler, photo attached, if your gas it bottles dont have this then it could be a problem as the Spanish adapter screws into the uk fitting.
    • Like Like x 1
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,888
    17,547
    YO11 2BD
    Have you tried the big supermarkets ?
    If they are anything like the French ones they stock almost every concievable item.
  5. RebeccaKristy
    RebeccaKristy
    Jan 27, 2015
    59
    16
    Cornwall
    Think it might be that. It is the external fill point, we have filled it in the uk?
    • Like Like x 1
  6. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,783
    13,655
    Norfolk
    • Like Like x 1
  7. RebeccaKristy
    RebeccaKristy
    Jan 27, 2015
    59
    16
    Cornwall
    Any recommendations near the a8 for big supermarkets? Only found the smaller ones so far?
  8. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,509
    9,935
    if its a standard filling port supplied with the kit, then yes the adaptor screws in
    • Like Like x 1
  9. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,783
    13,655
    Norfolk
    Worth checking the link from @jollyrodger in above post as if a Repsol near you , they may well have the adapter.
    • Like Like x 1
  10. CherryPirate
    CherryPirate Funster
    Sep 4, 2013
    156
    161
    Hants
    I don't suppose that there are any Brit vans near you that use the same adapter that maybe you could borrow for a short while?
    Colin
  11. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,804
    11,281
    E Yorks
    When we were in Spain earlier this year we needed to use the below French/Italian/Euro fitting screwed into our filler point (same as the one above in post #3) and then the garage used another adaptor which clamped onto it which the filler nozzle could be attached to.
    We found, however, that the Repsol garages usually had a large box of various filler adaptors so I'd be very surprised if they didn't have something to be able to fill you up!
    • Like Like x 3
  12. pappajohn
    Aug 26, 2007
    29,888
    17,547
    YO11 2BD
    Look for the French owned Carrefour and Auchan supermarkets.
    if anywhere it will be there.
  13. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,863
    roche cornwall
    lots of spanish adaptors are for the very small italian thread . its about half the size of the uk adaptor threads .
    think its a 10mm thread. is it tamasi or something that the italians use. i found spanish have had that thread on their adaptors for several years .
    • Like Like x 1
  14. olley
    olley Funster
    Jul 29, 2007
    3,762
    2,272
    Ipswich
    That's the Euro adaptor Larry which is supposed to be rolled out across the EU at sometime. Last time I was in Spain some 5 years ago some of the new garages had that, and the older ones had either the UK bayonet or the French claw gun. Nothing like keeping things standard. :)
    Ian
  15. jumar
    jumar Funster
    Nov 6, 2012
    869
    1,196
    Spain
    Download the app My LPG.
    Find LPG station near you, not too many.
    Go to location, they should have a Spanish adaptor that screws into your adaptor.
    Fill up.
    Caravan suppliers should be able to supply a adaptor for future use.
  16. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,783
    13,655
    Norfolk
    Hi Ian, when in Spain the last three years that was the only one we used but other than one fill up we used Repsol stations so i guess they use it as standard.
  17. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,076
    9,670
    Lorca,Murcia,Spain
    Here the lpg station has adaptors for every conceivable need.
    Yes my filler is the acme/German/French one & which I have to use a Spanish euro connector >10mm adaptor or a UK bayonet> 10mm to fill.
  18. RebeccaKristy
    RebeccaKristy
    Jan 27, 2015
    59
    16
    Cornwall
    No! Seem to be no brits In this campsite!
  19. Minxy Girl
    Aug 22, 2007
    9,804
    11,281
    E Yorks
    If there are any aires near you you'll probably find some Brits there ... just an idea!
  20. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    My Gasit external is same as one pictured. You will just have just go try a few stations to see if they have one. Most but not all have a box of them....
Similar Threads
  1. xtab
    7
    303
  2. syldale
    10
    422
  3. Pikeman
    16
    640
  4. Leltel
    19
    636
  5. bryandh
    342
