LPG for house and engine
Discussion in 'Motorhome Chat' started by motorhomelover, Sep 22, 2010.
  1. motorhomelover
    motorhomelover Banned
    Jul 28, 2010
    1,719
    613
    The world
    is it possible to fit an extra tank on an rv and then pump the gas in to another tank eg
    hold gas in one tank then use the gas by puming it in to either the house gas tank or in to the engine gas tank on a lpg conversion?
    i get about 230 miles to a tank of LPG i want to carrrie an extra tank say 200ltr of LPG then as one thank runs low on either house side or engine beable to pump it across to either tank
    any one know if this is possible?? what would be required? when can you fit it for me ??? heheheee
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,336
    17,057
    Liverpool.
    Dont know if what you want to do is possible as am not a gas fitter.
    What I have seen on Evilbay is LPG pumps so you can pump liquid gas it seems.
    Why not just fit an extenda stay and couple up to a bottle in a locker,much easier for the habitation side.
    I know where your coming from though,it would be usefull to be able to transfer to whichever tank you choose.
  3. johng
    johng Read Only Funster
    Aug 15, 2007
    588
    Kent/Sussex UK
    yes as far as I know, adding tanks is quite normal to increase range.. I dont think you swtich between them, rather they balance each other out if you get me. but may be wrong on this..
    any decent lpg fitting place will/should be able to add a tank :)
    sorry re-read your post .. um.. dunno ;) increasing range of the fuel side would be my suggestion, by adding a tank.. and using a normal cylinder to increase your domestic 'range' would sort that out.. (on my RV I use the BBQ out as a way of fueling the domestic, and still have the domestic tank present as well - so effectively two tanks)
  4. scotjimland
    Jul 25, 2007
    29,036
    25,726
    Suffolk
    Add another tank as suggested, connect the two tanks together with a 12v gas isolation solenoid valve in the line.
    Normal running keep the valve closed, if you run out of engine LPG then open it and the LPG will flow into the engine tank , both tanks will now have same level. No pump required.
    The valve can be controlled by a switch on the dash with an indicator light to show Open or Closed.
    It would work equally well other way round, ie engine lpg into house gas tank.
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,364
    18,054
    YO11 2BD
    not a problem for me.....
    i have a 30 GALLON 'house' lpg tank
    oddly, this is the original US factory fitted lpg tank and the plate says 29.9 gallons/135ltrs.
    i would expect the tank capacity to be in US gallons but 135 ltrs is 30 imp gallons
  6. scotjimland
    Jul 25, 2007
    29,036
    25,726
    Suffolk
    surprised it's not marked in US Barrels ....:Laughing:
