Low wattage bulbs (1 Viewer)
David27
37
44
Audlem, Cheshire
Class C
since 2014
Hi All,
Does anyone know where I can get lower wattage spot lights. The ones in my van are 20 watt, but they are smaller than the standard ones at only 35mm ( two pin push in type )
I intend to replace all my bulbs. I have two large circular ceiling lights but at present cannot work out how to get the covers off --Doh
Thanks David
treetops1
1,599
1,759
yorkshire/ lincolnshire.
Sold last van-
a long time,since 1996
You may find if you push up on the outer ring of your light fitting and turn it may well come off. Regarding your bulbs ,you will get what you want off Ebay.lol
David27
David27
37
44
Audlem, Cheshire
Class C
since 2014
Thanks for the reply treetops 1. Just been out to the van and tried to push and turn, no luck. Regarding the bulbs I have looked on ebay and amazon, but have not found what i want. The problem is I cannot read the type or style number on the current bulb. David
Mar 26, 2009
8,162
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
Put a picture of your existing bulbs up on this forum and someone will be able to tell the type.
Same for the large fitting too.
treetops1
1,599
1,759
Sold last van-
No problem David 27. But lots on ebay prob MR11,12V should be lots ,and sometimes held in place by a small circular spring .Happy hunting lol.
David27
David27
37
44
Audlem, Cheshire
Class C
since 2014
Good idea. I will put pictures on as soon as I can find the flipping charger lead to charge up the battery on my camera. David
Badknee
7,407
412,704
notloB
Vantage Neo
Living the dream.
@David27 a much better idea would be to replace them with LED's. Next to no power draw on them and no heat. (y)
Badknee
7,407
412,704
notloB
Vantage Neo
Living the dream.
You can get cool and warm. I put cool in the kitchen and bathroom and warm in the lounge for a softer light. I didn't bother to change the main fluorescents as they don't draw a massive current and we don't use them much. Plus I bought 8-30volt to take account of the fluctuation in battery output.
David27
David27
37
44
Audlem, Cheshire
Class C
since 2014
This is a picture of my ceiling light cover which I am having trouble removing. The van is an Elddis Autoquest 120.
Badknee
7,407
412,704
notloB
Vantage Neo
Living the dream.
I think it will be twist and pull David.
Anthea M
Oct 18, 2015
9,501
165,143
Sheffield
Hobby
Since 2009
We bought our replacements from Peterborugh motorhome show! Can't remember the name but they were very helpful! Sorry
Jul 31, 2014
1,930
3,241
West Yorkshire
EuraMobil Activa 820HS
Mine is similar. If you flex the white plastic it should pop out from the metal band
David27
David27
37
44
Audlem, Cheshire
Class C
since 2014
Well done Gavlad, spot on. Obviously I was trying to detatch the metal band, which I now know is screwed to the ceiling. I now know what is inside there. 9 watt fluescent tube. I wonder if they are worth changing ? ( 2 lights on the ceiling )
Feb 24, 2013
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
I am just in the middle of swapping one of my fluorescents, just need to remember where I put the roll of LED's now
I was surprised at @Badknee saying they don't take much current, our MH has a controller which displays drain on the leisure battery, ours takes nearly 3A, so definitely worth changing, although our light might be faulty, it comes on when it wants to, hence the change, it might be it is showing start up current all the time because the bulb wont light
also watch out for voltage issues, I was warned that you can get quite a kick off the fluorescent starter even on DC, you also need remove the starter from the wiring, or better still remove it, the output voltage is not 12V DC, connect directly to the incoming cable and fit a short length of LED strip (y)
Badknee
7,407
412,704
notloB
Vantage Neo
Living the dream.
I think your right about yours @DavidG58, the guy at Peterborough we bought our LED's from showed us that although the starter took a bit of leccy when lit it was quite low. As we don't use them very much at all I decided against changing them. We use the LED down lighters 99% of the time. (y)
